Using 9XR Tx with a PC simulator ?
Started by weavo56, March 02, 2014, 09:45:41 PM
weavo56
Can you use the JR  jack socket to connect to a pc for a sim program ?
Graham
Quads , 450,550,280's
mini Skyhunter
rob.thomson
Yes.
Yes the jack plug on the USB adapter plugs straight in, then you setup the trainer menu
weavo56
Great , where can I get a usb / lead from ?
Graham
mini Skyhunter
weavo56
Thanks for info , now ordered .
Cheers Graham
mini Skyhunter
just make sure you set up a fresh model memory for when using the 9X on the PC as a simulator controller.... then remember to pick the right model memory when you go out to the field flying the real thing.
weavo56
Yes good idea , I have set up a basic model for now , just waiting for cable to arrive .
Thanks  G W
mini Skyhunter
