Kk2.1 features
Started by Sommie1974, April 27, 2014, 09:17:08 AM
Sommie1974
The kk2.0 and kk2.1 board. I know they have self level, but do they have acro and manual or is manual and acro the same thing on these boards?
Manual is essentially an acro mode - although you can set it up to be very gentle or quite mental - it's all through the stick scaling.  So if you want fast loops/rolls then have the stick scaling hugh.  by default it's quite gently and a roll will take about 2 second to complete, so make sure you are up high before trying it :D
Sommie1974
Thanks curry. Had a big of a debate with my mate. He said it had 3 features and I said 2. One up to me ;-)
Sommie1974
Another question guys please. My low voltage monitor repeatedly goes off. I have the jst connector the right way round on the board. Got the voltage setting at 106. I have tried 2 buzzers and both do the same.
Any ideas?
jamesb72
Depending on firmware you can have 3 flight modes ie rc911 v1.6++ has self levelling, sl mix and acro. Sl mix is self levelling around centre stick but switches to acro at full stick so you can do flips/rolls but still self level when you centre stick which is great for fpv proximity stuff.
Voltage alarm, Ive read that it may not be accurate, ie up to 1v under reading, can you compare dvm to reading and adjust threshold downwards to suit, I think some firmware allows you to calibrate voltage so if yours does that may be an option.
Quote from: jamesb72 on April 29, 2014, 10:54:27 AM
I don't know if it's just the 2.1, but mine is measuring way under - maybe 1v, and when under load it's immediately beeping.  So I'll just replace with something else (either mini OSD or lipo alarm) 10.6 as an alarm voltage is too high IMO, you'll find that under load you'll be into the 10.x's pretty quickly
Sommie1974
Thanks guys. Wot you suggest it to be changed too?
