Getting there
Started by subarubren, May 17, 2014, 02:55:05 PM
subarubren
subarubren
haha yes still waiting for it lol contacted them today, they say its been in the uk since the 30th of april,, so where is it now
Quote from: aitch on May 17, 2014, 04:03:18 PM
Camera ????
Pfft camera is for noobs. Real FPVers read through the static signal just like in the matrix.
Gundummy
Bren,
        boxed up a couple of cams for you but still in my glove compartment ready to post because the good weather made me fly all day  ;D
Sorry but will post on Monday  :+
These are both 38mm single board cams so might be a little wider than your mount in that pic.... nothing glue won't sort!
you will need 3 pin mini molex picoblade type leads as i had none spare!
Regards,
GD
subarubren
thanks matey ill get one ordered
subarubren
not hong kong again lol you dont want to sell a couple do you  ;D ?
Worthawiggles
subarubren,
PM me with your address and I'll post you 2 x male and 2 x female connectors next week. No charge.
W
Gundummy
Thanks for that wiggles  ;D ... I'm plain out here!  there's 2 cams both with different 3 pin molex but which ever one you send will fit at least one of them.
Worthawiggles
#9
Be aware that the pin configuration may not be what is required by the camera. I have already fallen foul of this and burnt a camera because a step up power board had the positive and the signal wire in the wrong orientation. They are easy to change around. Lift the locking tab with a scalpel and pull the pin out. I would suggest you check connections before plugging in. Will post your connectors next week and let you know when done. W
Looking good Bren :)
Whats keeping that lipo in BTW ?
I would also at this point recommend some reinforced fibre tape on the bottom of it
subarubren
I haven't fixed it yet it was just for the photo, what do you recommend
Velcro on both the pod and battery, then secured with a velcro strap to stop slipping.
Tape : Packing tap
subarubren
