FrSky Taranis - Telemetry
Started by JezUK1, October 24, 2014, 07:00:55 PM
JezUK1
Hi guys,
Regarding telemetry on the radio I'm assuming it tells you signal strength but can you also get to tell you how much battery power is left in your craft as well as attitude?
Gundummy
#1
It can....... BUT..... it will need the sensors to send the right information.
If you're using Frsky Rx/Tx set u then you would need: https://www.hobbyking.com/hobbyking/store/__508__172__FPV_Telemetry-FrSky_Telemetry.html
for example...
the current sensor/Vario sensor etc etc
JezUK1
Gundummy
Signal strength and RX Voltage off the top of my head - to get more you would need to plug additional sensors into the smart port.....BUT
If you are flying FPV you would want that info on your OSD..... just an after thought!
