Arduino project
Started by Coyote, July 18, 2011, 02:05:39 PM
Hi guys, im wondering if an Arduino can accept a ppm stream ( well i know it can ) but add 2 or more channels to that stream and output it ?
Or could it read a nun chuck, and be used to translate the data to ppm channels to work as a slave tx ?
Im still waiting on a chip that could do it, but then i wondered if an Arduino pro mini could do the same thing but better ?
Shikra
Yes - easily supports that. Funnily enough I was going to do a similar project. Might still one day when others have finished (!!)
roofmonster
Hi
Im sure nunchucks use I2C to communicate so the arduino will easily handle it.
John
How would i go about it ?
roofmonster
 I have done a few projects with arduino and there is usually someone that has done the groundwork for you
There is a Wii nuncheck library here that will simplify things
http://www.arduino.cc/playground/Main/WiiChuckClass
Have you had any experience with the arduino?
Funky Diver
Seems the answers are here :)
Good to see you getting on with 'avin' a go with Arduino :P
Cheers RoofMaster, lots to be learning now :)
