My Radian with the going camping look
Started by martink1974, June 14, 2011, 12:28:49 AM
martink1974
Well thought id get round to postin some Snaps of me new Radian
has gone well so far allthou there is little space for my kit in her , had to gut her abit , but it flying lovely now , never wants to land lol
have reinforced tail abit with horizontal fiberglass strip out of old parkzone wing
my osd is in tail with lc filter for tx and cam
have a 1300mah for video that needs to go in time needed weight to ballance her
also a 2200mah for main esc and a 3a bec in belly powering osd and fy21ap / servos
esc's bec is just powering reciever
ive also built a more substantial  groundstation lately but im haveing more video issue since doing so used to get better video when had m8 holding same patch antenna with reciever on plastic bag on field beside him
thought id post pics incase you guys can see where im being mad or not so mad :)
anyway let me know what ya think
Shes looking packed, lol, I have the same problem, trying to get all my kit in an easy star.
regards G :)
electricmick
That's why I switched to the flying truck - Skywalker
Blimey, impressed that you fitted all that in there.
Yup thats a lotta kit in not a lot of space, well done :)
DPS-Dave
WOW where you in the boy scouts ? You should get a badge for packing that  ;D
Fair play but have you tested that it works?
Those wires are awfully close to each other, you might get interference when you open the throttle for instance.
gavjak
Are you using the standard folding prop? I found it to be really lacking in power before installing all my FPV equipment. It would have struggled to gain altitude! I changed the prop for a Graupner CAM 11x8 and it is a power house. Pulls vertical with the standard motor with FPV equipment installed and only pulls 20 amps. Great for getting up there and doing what the Radian does best. The Graupner prop is an easy fit. You just need to drill the holes out on the root of the prop to fit the Parkzone spinner pins. Folds back flush with the body just the the original prop. Best mod I have ever done for £6.
http://www.puffinmodels.com/product.php?prod=988
I swapped for a 11x8 on mine, much better, i upgraded the esc too :)
martink1974
new prop might just solve my problems with this was strugling to climb high some days ,
im gunna revisit my raiden realy soon ,
too many projects :)
martin
I was toying with revamping my old chris-foss centi-phase for fpv but the more i see of the this model the more i like it. :D
Are there issues with the prop up front for your camera guys. ?
dizzy
It can be annoying, but once i tried it i found it not that bad, plus once your up there you cut the motor anyway
give me a clear view with a pusher prop any day :)
G
I can see the prop on my easy glider pro, it doesn't bother me as once your up the motor is off most of the time anyway.
