Long range 35MHZ RX
Started by Miles, August 21, 2011, 05:06:15 PM
Miles
Hi Guys, as some of you know, I have been using 40mhz for flight (:o).
I have now got a JR X-378 and a GWS GWR-8M, however this is a low range (300m) RX.
I am looking for something that supports RSSI mods, has decent range, 7 channels and it would be nice if it was synthesised. I was looking at the Corona RP8D1.
BW
Wings: 2*X6, 2*X8, Z84
FW: Wot4, EZ*2
SZD Pirat 1:1
300m on the ground will be a lot more in the air
Miles
Still doesn't seem like a lot, looking at a corona
QuoteRS810II has improved the receiving range as far as 1.5Km (checking range on ground).
Link: http://www.giantcod.co.uk/corona-single-conversion-rs810ii-receiver-p-402404.html
But how much do you reckon it would be?
BW
FW: Wot4, EZ*2
SZD Pirat 1:1
Sheldon Holy
Use this one:
http://www.giantcod.co.uk/corona-rp8d1-synthesized-dual-conversion-receiver-35mhz-p-402647.html
It is great. Cheap as socks, much better interference wise than more expensive receivers, and it is synthesized and things. They're very good. I use one. Most people use them.
I have several Corona RP8D1 receivers all purchased from Giantcod and they work well. Do not use above channel 80 as there is some problem with locking on to the higher channels. Occasionally I have a minor problem when locking on to a channel for the first time but once done there are no further problems.
As regards range, if you install properly with the aerial wire extended as fully as possible you will have control as far as the eye can safely see. Beyond that you are into a no-go area as far as regulation goes in this country.
Miles
Thanks guys. I think I will get a RP8D1, I am using ch 71 so it shouldn't be a problem.
I was planning on a few mods too, i am going to make the Areal 1/4 Wavelength and add RSSI. output on the 8th channel, and also connect by 6V NIMH to the RX to ensure continued power if flight Lipo fail, as well as connecting said batt to Elogger.
Thanks for input guys
BW
FW: Wot4, EZ*2
SZD Pirat 1:1
Miles
Thanks for help guys, ordered a Corona RP8D1 and a 11X8 Prop from giant cod, should arive on tues :)
BW
FW: Wot4, EZ*2
SZD Pirat 1:1
ORCA
#7
Unless they have changed the instructions for the Corona RP8D1 they may be a little hard to follow as they are in 'Chinglish'. Try these by Devonian on the GiantCod forum.
http://www.giantcod.co.uk/forum/viewtopic.php?f=8&t=5629&hilit=#p19088
Only use channels between 60 to 80.
HTH
Devonian
I forgot I'd posted that on the big fish forum.
Thumbs up from me on the RP8D1  :thumbsup:
Personally, I've never played with aerial lengths, but here are some interesting facts by Mr Rc-Cam
http://www.rc-cam.com/ant_exp.htm
Nigel.
Miles
Thanks guys.
Also found some english instructions on coronas site:
http://www.corona-rc.com/coproductshowE.asp?ArticleID=63
BW
FW: Wot4, EZ*2
SZD Pirat 1:1
