Just ordered a Flyingwings Falcon EVO. Need advice.
Started by markwilliams, March 04, 2016, 09:36:04 AM
markwilliams
Hi guys.
Can't wait to build this one.
I am after some advice regarding elevon throws.
I understand they need to be rather small.
Do I need to build in some reflex as well?
Thank you gents.
Mark.
MT
FX-61 Phantom
MTD
Falcon Evo
Phantom 3 Pro
Have some dual rates setup, wings don't need a lot of control surface movement and can be a bit twitchy.
All wings need some reflex (which is just a bit of up trim) If you lay a ruler along the underneath of the wing and follow that shape that should be plenty.
AdamG
Hi Mark,
Go to the following page and click the 'Manual' link. Gives you the recommended throws: http://flyingwings.co.uk/fpv-uav/fpv-wings/falcon-evo-range/falcon-fpv-wing.html
I set mine up with Triple rates, and 30% Expo.
Hth   :)
Brod
very small throws on mine,adjust mechanically to achieve it so better servo travel resolution..
I did a video to check it..
http://youtu.be/0G_SpbThg7U
never ever give up...
markwilliams
Brod.
Your video has gone!!
OK.
Falcon fuse built, electrics and FC fitted, FC cal and set up complete and foam painted.
Just waiting for my lam to turn up.
Mark.
MT
FX-61 Phantom
MTD
Falcon Evo
Phantom 3 Pro
