EzUHF v1.41 firmware problems?
Started by DaveyLC, April 13, 2013, 04:18:11 PM
Damn I didn't read the release notes properly:
Switch from 9600 baud over-the-air rate, to 19200
This brings us many advantages, but as a side-effect gives a very slight reduction in sensitivity. In most cases this will be barely noticable (< 1dB).
Support for up to 12 channels
The higher data rate now allows us to send up to 12 channels of PPM from compatible R/C transmitters. This functions with current EzUHF transmitters, no hardware change required.
The list of compatible transmitters is still TBD, testing was performed with the er9x firmware on the Turnigy 9x, which has a very flexible PPM channel count/frame rate control.
Spekrum DX8 Glitch
Its come to our attention that too many n00bs are using Spektrum transmitters; we determined that DX8's use a 27.9299ms frame spacing so when that is detected the air-craft will automatically pitch to 70 degrees nose down and an engage full throttle.
