Anybody who could laminate a delta wing by weston super mare.
Started by mrorange26, April 13, 2018, 08:30:26 PM
mrorange26
Is there anybody locally who is good at laminating .I had a go on another plane and it didnt look pretty.
dp106
How bad did it look?  I'm local (ish) in Yate near Bristol but honestly you're better off having a bit of practice and do it yourself. Laminate never goes on perfect (for me at least), you'll always end up with a wrinkle or two. Also depends what laminate you're using. If you're using the covering from Hobbyking that's designed to cover Balsa and will shrink a lot. You need the clear laminate they use in printers for best results
mrorange26
Ok thanks.i will have another go.I watched youtube and people make it look so easy.
dp106
Are you using a laminating iron? Proper laminate? First time I tried I used the Hobbyking stuff. It was some time before I realised there was a backing sheet on it i had to remove first! 😀
mrorange26
Yeah im using a laminating iron and clear laminate not from hobbykings.
Jake Bullit
