EZUHF Upstat
Started by Andy Sayle, October 29, 2019, 02:21:16 PM
Andy Sayle
Hi folks,
I don;'t suppose anyone has any information on the "Upstat" option within the EZUHF setup software?  It can be selected to be output as one of the slots in a PPM stream.  I have used RSSI and LINK before, I get those, but I can't find any info on what infor UPSTAT contains, nor what format the data is output in.
Its for providing the OSD with the link details, unidirectional only though.
Andy Sayle
Do you know what info is passed along though, and what format it is in?  I'm hoping it will provide RSSI info for each of the two antenna on the 8CH rx?
Uplink Status (UPSTAT)
All uplink status is available in the single-cable PPM stream for use by supported OSDs. The XuGong v2/Pro, or the upcoming XuGong Vortex both take advantage of this method to show critical uplink status on-screen.
The received signal strength (RSSI) of each of the receiver's antennas, along with the link quality, are captured by the OSD, and displayed with appropriate alarms to indicate marginal conditions.
