Autopilot FY21AP+AP117 Bench Test
Started by Njoro, December 04, 2010, 06:44:04 AM
Njoro
Here it is ready for the Ursus.
Thanks Simon for the quick delivery again :D
FY21AP+AP117 Bench Test.
Here is part  of it that I missed :-[
FY21AP+AP117OSD Bench Testing.wmv
n00b@FPV
very nice
thinking of getting one of these beasts
may sound a bit weird but could you possibly make a video or just write it. about all the switchers you need for the rtl and abm and stuff
Very nice Lance, its a whole lot of kit, needs a lot of room but feature packed :)
Njoro
#3
Quote from: jakerevell on December 04, 2010, 09:40:51 PM
very nice
To fully utilise the features you need to have 2x 3 position switches. Radios being different I'll use my JR for now.
The booklet can be slightly misleading if you are not sure about pulse width but with switches there is no need to worry as long as they are set to ATV +100, -100.
In the JR9XII I chose to use " AUX 2 Channel  6" which is the Flap switch and then I needed to configure "AUX4 Channel 6" to Flaps in Device select menu then set it to ACT. So now my radio shows 2x Flap enabled switches in the Device select menu, this is where you configure a switch to do different things. IN2 overrides IN1
FY21AP
Switch IN1-channel 5   0-Position = Deactivated.  1-Position Stabilized Flight.
2-Position Fixed Altitude Flight.
Switch IN2-channel 6   0-Position Return Home.   1-Position Auto Pilot Deactivated.
2-Position Auto circling.
AP117
Chanel 7 controls the overlay.
Njoro
Ooops I just realised I posted the wrong video clip  :o
n00b@FPV
haha dosent matter just post the one you ment to do under here  l
        V
Njoro
#7
Video added to first post :)
