Bixler OMT build.
Started by marcin, September 12, 2012, 01:22:45 AM
marcin
Here is some pictures of my shiny Bixler build ,already got 3 LOS flights done in really crap conditions.
1. Wings need better carbon rod "full 6mm" not tube.
2. make it easy to connect servos for ailerons. "servo connections outside fuselage"
3. engine and fuselage section above wings connection covered in epoxy "will do same with whole nose section" really light and strong.
4. not FPV gear on it as I destroy one POD and waiting for another from HK. "whole FPV gear weight 60gr" and got nice range.
5. all up weight 860gr with FPV gear ,2200mAh 3S Lipo
Pr][nCe
looking good,
as for note 1. just insert a solid rod 4mm or was is 5mm. into the supplied tube for the wings,
Tricopter.  FPV.
2014 Skywalker 1800.  FPV.
Emax 250 Pro. FPV.
Bixler. Night flyer. LOS.
Versa Wing.
marcin
So ,decide not to wait for HK delivery and create this.
No interference at WOT.
Light and easy to connect.
Super simple.
