Tarot FY 680 and a bit Hexacopter
Started by Coyote, January 20, 2013, 08:10:52 PM
I love the frames, that`s why I decided to do the Quad as well, they are very strong, my only dislike is the carbon on the bottom of the landing gear, I have replaced the Hex`s, the Quads new piece is on its way over
Looks sweet Ian, The only reason I fly quads, is that I can't afford X6 T-Motors and props  :laugh:
;) G
Does your quad support coaxial configuration? Been hoping to get a Y6 or X8, that being said the foldable T810 looks sweeeeeeet.
You could configure it as a x8 and the Hex as a y6 yes
Faffer
Looking good ..
so not upgrading the hex any more then ?
I need to work out what frame to get and plan a nice upgrade from the DJI 550
Richard
R I P DJI 550 but welcome TBS Discovery
Oh yes, the Hex is just waiting for its new gimbal that should get delivered in the next few days. Then it will be carrying my Nex camera
Seeing I have ploughed a bit more money into this Hex I figured it could do with looking a bit better. One of my pet hates are the cable colours being all over the place so I have replace none matching cables including the Vtx cables with JR style Orange/Red/Brown to match the rest of the system. I have now also relocated the video switcher to the rear of the Hex.
I made up cables with connectors for the DesireRC prototype gimbal board
Now my new favorite toy :) The Kamkop.de gimbal for the Nex 5N, it really is a work of art this gimbal, not cheap but so solid, so well thought out, it`s not going to be replaced, it works brilliantly
Those huge looking motors really are ! They make my RCTimer 5010`s look tiny even though RCTimer class them as 5010`s lol They have bags of torque so now I can actually use it to film with ( kinda handy I know :) )
The IMU goes on top above the camera which is then neatly hidden and protected with a plastic cover also supplied with the gimbal, nice touch ! Also a nice touch is the camera tripod screw they supply for securing the camera. It is a nice touch, but secure maybe a strong word, I will be adding some rubber webbing to the camera base to make it more secure.
With the new gimbal though the balance had shifted right forward, to sort this out I have now took to mounting the main flight lipo to the top of the Hex and using a separate 2200mah 3S for the gimbal and FPV equipment, for balance and very clean power for non flight related equipment.
That looks so expensive to fly now i would be getting nervious  :D
dizzy ;)
MarkLincs
#113
I think I'm going to get that gimbal set up....
limits my cameras a bit but I need a decent gimbal....
- Still learning every day -
Well after a few flights now I really like the setup, I have judders on the roll axis when trying fast forward flight, but Ill get rid of that.
What I am not happy now with is the flight times, she now weighs in at 3.5kg in weight ! The RCTimer 4215`s 650KV motors do lift it, and it seems to fly OK, but my flight times are now down to 6 mins max. What`s noticeable though is the lift off and hover, it now does not lift up at 50% throttle and altitude hold doesn't work very well anymore, this will be down to the motors now being overstressed / under rated for the task.
I`ve been chatting to Hase about motor choices and he is sending me up some T-Motor MT2814`s 770KV to try out instead.
T-Motor MT2814 770KV
From the numbers we were running we have broken it down like this :
Weight of frame = 3.407kg
Max thrust required = 1156g ( Each motor )
ESC`s max rating = 30 Amps
Hover thrust required will be around = 578g each motor
With that in mind, 10x3.8 props on 4S gives :
50%  throttle - 4.1 Amps - 550g of thrust
65%  throttle - 6.8 Amps - 770g of thrust
100% throttle - 20 amps - 1440g of thrust
So at just over 50% throttle I should have enough thrust to hover at say 5 amps per motor, that`s great, 20 amps max, good also and 284g more than required thrust per motor at WOT. At around 5 amps hover that should give me a very decent 10 mins flight time per lipo, much better !
Option 2 is using 12x3.8 props
50%  throttle - 6.6 Amps - 810g of thrust
65%  throttle - 10.5 Amps - 1060g of thrust
100% throttle - 29 amps - 1950g of thrust
This means at under 50% throttle I have enough thrust for hover, brilliant ! Slightly more amps used though, 29 amps which is still OK for ESC`s and 794g more per motor than required at WOT.
So which would you go for for the best performance / flight times ??
MarkLincs
I have those motors but have gone 11x4.7 gen  props
I know the Vulcans slightly heavier overall but I recon 10 mins should be possible
Better update progress while I`m at it :)
The new IMU turned up, no noise now on the GUI which is good, that meant I could also now mount the IMU under the cover not on top of it making it look much better :
The problem I had with the gimbal after some experimenting was down to vibrations. So I whipped off the original Tarot dampeners which are great for lighter cameras and put on the base plates and dampeners from the useless Goodluckbuy gimbal I have now sitting around :
Right now the camera is cable tied to the base, the base cable tied to that Tarot, yes ........... I cable tied a Nex 5 on :) :) :) Its working remarkably well so I will replace the ties with drilled holes and nuts n bolts soon :)
I had also ordered the Quanum 2.4 telemetry system from Hobbyking. As I have been having unreliable results from my lipo alarms and inconsistent performance from my lipo`s I wanted a system to monitor in real time all the cells so I can have a clear and informed reading of the state of play.
It turned up today, so the receiver went on my 9X :
The transmitter is yet to be fitted onto the Tarot, but I have had the system setup and working fine. The receiver is a tiny unit that could go on even the lightest of multi`s or planes for that matter and I have a feeling, for $50 this is going to be a very good investment
Still waiting on Tarot spacers for the gimbal board ( yes its just hanging off the back ) the right HDMI cable ( ordered the wrong frekkin one :) ) and the motors / props swapping. Then, eventually, I think I`m done with it and ready to actually get some filming done................ Bring on the drifting !
hase2
Just use 2 batteries. with the 2814s you have plenty of lifting power.
Two lipo`s is do-able, but wit which props ? :)
