Coyote`s Eazystar Build
Started by Coyote, October 18, 2010, 08:50:31 PM
mark1975
nice one ian that should help with flex in those high speed dives ..lol
https://plus.goo
hpmc
hello ian
could you tell me please how you have wired the Gopro up i see you have wires from the usb and the jack plug.have you used the gopro battery or take power from the rx.rgds jeff
Hi Jeff, what i did wiring wise was get an angles 2.5mm 4 pole jack plug prewired, i took the video out wire and ground and took them to my EZOSD video in and round.
The USB connector was one left lying around. i cut and stripped the cable and took the red and black to the Immersion 10mw vtx Camera 5v supply and ground. It powers the camera as i fly :)
maddirk
Quote from: Coyote on October 21, 2010, 09:03:54 PM
Ok quick update :
First the camera pod, because pan servos tend to be first effected and need to be kept super still i added a ferrite ring to the servo lead. 5 wraps rounds enough to work effectivly
Next thing i wanted was to mount the vtx and EZOSD so they were accessable so i could adjust the Osd without ripping everything to bits or change channels on the vtx. Here`s how ive mounted them :
The height was govened by the antenna height i wanted and cable connectors having to clear the lipo. Also there would be a birds nest of wires so i donned the soldering iron to simplify the wiring and improving clearance :
Next on the list was to mount the current sensor to the EZ. By doing this it means fitting the pod is a three wire affair, all connectors are locking apart from the servo connection to pan servo.
I mounted the current sensor, tapped into it and got the feeds for the RSSI reading and display toggle input. RSSI on a UHF receiver might seem pointless but i think that monitoring it would let me know of any problems and might save an accident.
I then fitted the elevator servo wire, the pan servo wire and ailerons. Then spent a bit of time making it as neat as i possibly could :)
Hi Ian, this is such a great thread, would be cool to be able to supersize the pics, I just want to see all the detail !  :)
Cheers,
D
sail away with me, honey
I wish i could but i shrunk the originals Dirk so i cant restore them im afraid :(
