Propellers for TriCopter
Started by john888, May 08, 2013, 09:16:12 PM
john888
#15
Quote from: vanmantony on May 10, 2013, 09:50:06 AM
john, stick with your tri you won't be disapointed I've built 8 0r 9 now for myself and others some with lights on some folders, all on a similar line to rc explorers. I did make 2 quads for myself and a friend but after a day flying them me broke them up and turned them into tri's.(cannot get on with the handling of quads) I also have planes and ic heli but to be honest I haven,t used then in months to much fun with the tricopter's. If you get stuck with anything give us a shout but following Davids build thread is as good a way to get into it as any cheer's tony
P.S couple of close ups of a build might be of intrest
Thanks for the encouragement Tony. I do not know much about aerodynamics but I suspect that the long boom in David's design helps in making the tricopter more docile or should I say less twitchy.
Your body plates look like aluminium instead of carbon fibre. Did you make them yourself? I have bought two carbon fibre plates from FlightTest for my first build. I intend to make my own body plates from thin plywood in future. I may lazer cut them at FabLab in Manchester as it is free to use their facilities on Fridays and Saturdays.
John
Get these, brill props for the money, not quite APC quality but for your first props you wont go wrong
http://www.giantshark.co.uk/propeller-10x47-black-p-402698.html
vanmantony
john, well spotted 1.5mm alloy plates, had a few lengths lying around so used them, also used for yaw mech done 5 or 6 like this always work super smooth and as they are on top of arm totally crash proof
couple of pics might be worth a look
cheers tony
