flyingwings.co.uk Venturi FPV and laminating
Started by krikey, July 02, 2013, 12:26:07 PM
180-190mm BACK FROM THE NOSE POINT
It's from the tip of the nose. If you've put a GoPro box in place already you will have to guess where the nose converges, eg. as you have already said you can draw an imaginary line.
The fpv version never had a pointy nose, the GoPro section is already cut out.
mali67
i have measured 190cm from the flat nose , and my cg is that far out ive had to add 400gms of weight  :o , makes me think these are only designed for the gopro. as im not using a gopro on this one, its kind of annoying
maybe i should have ordered the gopro version with the gopro box, least i could have put my sandwiches in there :P
to add i have put everything as far forward as is possible
krikey
Rob from flyingwings.co.uk came back to me to confirm a few questions regarding the Venturi FPV.
Q1. What spray glue should I use?
A1. There is no need for spray glue when using laminate, if you do, then the
spray is a little thick, best use frame mount
Q2. How should I measure the CofG in the Venturi FPV?
A2. Measured from the blunt nose.
Hope this helps a few people.
Krikey
So it's measured from the blunt bit where the GoPro sits? I'll have to measure mine and see where I'm at.
ROVguy
That's where I measured mine from, I will find out tomorrow how it flies.
Well, by a stroke of luck in cog is spot on with the lead ballast I've already got!
But I think my thrust angle is out. When I throttle back the nose drops. I think that means I need to angle the motor down a bit?
mali67
anyone have issues landing ? i mean i turn motor off prolly 200 meters out and glide it in and it still seriously fast, nearly taken my legs from under me a few times today lol
it flies amazing, glides for ages
mine is still tail heavy but flies like its nose heavy
Yeah mine glides for ages. You can't come in for a steep approach because it will be to fast!
Do you use a folding prop? I don't.
Still we would be complaining of it flew like a brick!
krikey
Just started glueing the wing together tonight and working out what my colour scheme is going to be.
Krikey
mali67
no folding prop, just a 10x8, im thinking ablout airbrakes or a chute lol, ive never had a model that comes in so fast
krikey
#27
Ok so first few pics:
At the rear of the Venturi all the EP should line up flush.
At the front, there is a "chin" which should sit below the wing with the upper shelf of the chin being inline with the bottom of the wing.
Krikey
krikey
Question: There are two pieces of ply you get to mount underneath. One runs from front to back and one runs across the back and acts as a mount for the motor.
The longer piece, even when bent into shape with hot steam is long enough to tuck underneath the engine mount plyboard. Should I tuck it underneath (as shown in the instructions) or maybe I should apply the engine mount ply first and stick the skid board over the top so that there's no lip when coming into land?
Krikey
mali67
Quote from: krikey on July 09, 2013, 11:16:04 PM
i had the same thinking of you, so i put the motor ply on first
