Sander Style For video?
Started by Anarchy83, May 05, 2014, 08:54:03 PM
Quote from: Anarchy83 on May 06, 2014, 12:00:34 AM
Based on this formula,  Why does Sander make the 433Mhz monopoles 164mm long? Surely they should be 173mm?
Because you are using the speed of light in a vacuum, not the speed of light through copper. Multiply the result by a shortening factor of 0.95 for copper and you should get your result.
The dielectric effect of the material you surround the antenna with (e.g. RC aerial tubing) also plays a small part.
Neil.
Ynot6
Quote from: Steve W on May 06, 2014, 12:31:06 AM
Er, are we sure light only does 300m per second? I beg to differ :laugh:
you're quite right steve, but we use 300 and megahertz, gets rid of all those 0s.
OMG, IT FLIES!
Ynot6
devonian, frequency in megahertz.
OMG, IT FLIES!
38 mph apparently (17 m/s) ...
    http://abcnews.go.com/Technology/story?id=99111   :)
some good information and links here, will take a proper read when I'm home.
