459MHz UHF legal Tx and Rx - Arduino based programability.
Started by Devonian, July 10, 2011, 02:54:30 PM
thundead
Yup that seems right since the tx rx pins go straight into the arduino IC. It should follow the standard FTDI layout anyway :)
Mihai.
papa_lazerous
thundead
Wish you luck :D I'm currently trying out a different FHSS algorithm. we'll see how it goes :D
JoeBloggs
Quote from: thundead on July 19, 2011, 02:16:33 PM
Aaa oki, thought that was it.
Think I saw one of those on the flytron website aswell so I can might aswell get everything in one go. Does that adapter in your post has a mini usb port?
Cheers,
Mihai
saw this video, is this what you were asking about?
OpenLRS Rx v2 Programming
Devonian
OpenLRS just keeps getting better...
Now with MultiWii 'copter control embedded in the Rx code, just add components as required.
http://www.youtube.com/watch?v=1Yco_i9vtnk
From Flytron forum
http://forum.flytron.com/viewtopic.php?f=7&t=4&p=1794#p1794
Nigel.
thundead
Hmm interesting but I think it;s a bit overkill for the atmega 328... better have stand alone controllers in my opinion :)
Quote from: Devonian on December 28, 2011, 07:53:19 PM
From Flytron forum
Nigel.
ghost2212
What frequency does the V2 reciever run at?
Brett
thundead
Can run any frequency in the following ranges: 433-470 or 868 - 915 Mhz.
Uk firmware runs on 459Mhz
Here is the datasheet for more info: http://www.flytron.com/pdf/RFM22B.pdf
Mihai.
Quote from: ghost2212 on January 08, 2012, 06:45:04 PM
Brett
ghost2212
Quote from: thundead on January 08, 2012, 06:49:36 PM
Mihai.
Brett
Sorry what I meant is what clock frequency the atmega runs at?
thundead
lol it's an 328p clocked at 16mhz :)
Quote from: ghost2212 on January 08, 2012, 06:53:02 PM
Mihai.
Brett
ghost2212
Quote from: thundead on January 08, 2012, 06:56:03 PM
Mihai.
Brett
But if its running at 3.3v then surely thats above the safe threshold that atmega recommend on their datasheet, according to that you need 3.86v to run at 16mhz. We put 16mhz on the DIY boards we are doing but cant get the first one to program(though we did burn the pcb a bit)
Brett
thundead
you could try supplying 5v to the atmega and see if it works. it should run at 3.3v ok as well.
check your tracks as well might be something wrong there. ALso , the ICs dont come with a bootloader. So you need to burn a bootloader onto them before you can load any arduino code.
Badger
Does anyone know of a good source of 459mhz antennas? I'm working on designing and building an STM32F4 (with hardware FPU, much much faster than the ancient avrs) based receiver using chibios RTOS, with inertial sensors and an RFM22B, and would like to do some proper testing rather than with the 433Mhz antennas I have so far!
thundead
there you go mate http://www.firstpersonview.co.uk/antennas/433459mhz?zenid=f2o2tks3o1bmvu3i6puhu6iv74 :)
Quote from: Badger on January 30, 2012, 11:14:35 AM
ollyb
Hi All
Just been reading this thread with interest as I'm planning on getting into FPV (and possibly autopiloting). Seems there are a multitude of options for TX and RX (not thinking about video freqs at the moment), but 459 seems to have great range and is two way too.
I'm seeing a lot of talk about patch antennas, so was wondering if the EIRP rule applies to the 459MHz freq. For those that don't know, the EIRP (Equivalent Isotropic Radiated Power i think) is the power needed to produce the strength of signal that you've got using a patch antenna (for example) but by using an omni.
For example, if you've got 100mw tx and an 8db patch, to get the strength of signal the patch produces but by using an omni, you'd need 160mw tx. (number picked out of the air, but you get the idea.
In the UK, wifi frequencies, for example, are limited to 10mw EIRP, which basically means sticking a yagi on a 10mw tx makes it illegal.
Does the same rule apply to the 459MHz band. It would be bad to go to all this effort to remain legal if sticking a patch on it makes it illegal!
