Mini Skywalker build coming up
Started by g.collins, August 11, 2011, 09:35:33 PM
cornishairrc
there not very good but flyable and light my mini skywalker has one
fpsazerbaijan
Hi everyone!
Would someone mind sharing details/images of how they're holding the horizontal stabilizer on without glue? So it can be packed up easily for transport...
I've seen a photo by someone on RCGroups that shows some sort of nylon screw...
Cheers and happy flying!
-Al
fpsazerbaijan
I suppose you could sink some tubes down the fin, and screw it on like its big brother.
;) G
cxlabs
hi mates,
hi g.collins,
i want to share how i reinforced
miniskywalker tail (try n. 3 eh eh)
it happens that rudder broke after
10 good landings...
Then chalk nose for camera/no camera fly...
good night!
Nice modes mate, looks great.
;) G
hangerrat
Hello,
I am building a Mini-Skywalker too, but was planning to NOT use the rudder. Does your MS with the FY21AP indeed use the rudder? Or have you left this off?
I wonder if the FY21 can still stabilize flight and do its other autopilot functions with just the ailerons and elevator/
Hr
Hi Hangerrat, the MS with the FY21 has a rudder fitted. I'm not sure if it will function without it.
Good luck with the build, you wont be disappointed, my SW with the FY21 and AP117 is brilliant, I fined that I use it the most.
please post up your results on hear, it will be great to see how it comes out.
:) G
hangerrat
Thanks G,  I might go ahead and connect up the Rudder.  I was trying to keep weight down, and the first pass is including a Nova OSD. I found a lot of folks using the Nova on this little bird are NOT using the rudder. Hmm, we'll see.
I bought two of the MS, for backup parts, etc. And because they're cheap! But I might just fit out the fuselage #2 with the FYAP, then be able to swap out the top wing/motor/esc combo.
Thanks again, great info in this thread.
