Ben's Venturi EVO slow build !
Started by benitoculito, January 24, 2015, 07:25:24 PM
I ended up using the mount from my Ninturi which I had bent a couple of degrees back towards the thrust line. Bruno's mounted his underneath the ply rather than on top, which I think is the way to go.
benitoculito
Just fallen at the last hurdle ! Got just about everything in place, did a bench test and am getting an error code on the osd screen, "graphics error email support " where's this come from ? The osd graphics are jumping all over the screen when I give it a little throttle ! Any clues !?
stevec
sounds like two unrelated problems to me.
if you spread out the bits you can remove and try again do you still get the noise?
I think you are getting some induction into the Video feed from something in the section with the Rx and FC in it.
as for the other issue no idea...
Steve
Are you running a separate BEC? I can't see one in your setup and got a little noise on throttle with my JP ESC until I used a separate BEC.
benitoculito
I was thinking about a separate BEC, hopefully that will be the answer, I will also have a look after work tonight into moving a few bits about to see if it is picking up noise from anywhere else. I re flashed all the firmwares last night but it was getting to late to try anything out. Cheers for the advice guys, I guess the maiden may have to wait another week or so.
benitoculito
I picked up a UBEC from firstpersonview today, it's a Henge 6A max 8A 2-6s Lipo. But if using an osd do I want to power the rx or the osd, if I remove the power from the throttle cable which is plugged directly into the osd, can I plug the UBEC into the audio input of the osd to give power, or plug it into a spare channel on the rx which will then power the  osd ? I'm confusing myself here !
