Raven Racing Series
Started by Brucey, January 30, 2015, 02:56:33 PM
Quote from: Brucey on February 12, 2015, 05:39:47 PM
Andy you should buy a vent so you can properly test you osd
There may be other options, talk to you at the weekend if you're about Andy...
Quote from: iPeel on February 12, 2015, 10:12:02 PM
Yep. Should be able to get out if the weather is good :)
Provisoinally Sunday?
Quote from: skyscraper on February 12, 2015, 10:47:43 PM
Sounds good mate, I'll mail you Saturday.
Dodge
Well, when I looked at the wing I wondered if I'd need to mount my camera off-centre... which you guys have pretty much confirmed... unless you have some tiny thing.
Quote from: CurryKitten on February 12, 2015, 11:40:58 PM
I bought one of these from Banggood: http://www.banggood.com/FPV-14-CMOS-HD-Color-Camera-Module-600TVL-120-Degree-Wide-Angle-p-944546.html
They're the size of the original FatShark cameras and run on anything from 5-15v. I knocked up a plate that acts as both the battery mount and the FPV cam mount:
As Brucey pointed out last weekend, the camera's toast if I have a nose-in but the way I usually crash, everything is.
Neil,
You could try an enclosed mount like I used n MySpeedster..
Not the same shape obviously..
I'm tempted to sink it into the wing like I did on the Falcon...
Good for speed and looks , but the unfortunate side effect is that, when the ground is wet... it acts as a water scoop. :pint: Might do it again, but have the option this time to lift up out of the muck for those squelchy flying sessions...
Dodge
Managed to get out at weekend and try get some formation going, still needs some rates setting up!
https://www.youtube.com/watch?v=3FMCgUJ3gL0
Quote from: Dodge on February 17, 2015, 09:09:05 AM
Looks like you got the makings of a good racecourse there.. 5 or 6 Ravens going through those tree gaps and there will be Mayhem and Carnage ..
(BTW: remove the s from httpS and your vid looks like ...)
Raven formation x2
Dodge
Yeh not a bad spot, some lovely arching lines here and there
ah cheers! Will keep that in mind =]
elmattbo
#55
By Crikey it flew! I was so expecting to bring the thing back in a bin bag and I only had time for a quick circuit but it was really nice! Launched with half throttle and never even got near full. Might dial down the rates as it's fairly lively and the elevons need adjusting as it has a nose diving tendency, but it all went much better than I imagined!
It's the first time I've built something like this so there was plenty of opportunity to make a mess of it. It needs the loose ends tidying up but I'm looking forward to trying it out fpv now.
Matt
Dodge
Thought I'd add a little colour to my wing ;)
Forum name / racing number up next
