FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 154
  • Dot Hidden: 0
  • Dot Users: 0
* Site Sponsor
* Random Gallery Items
raptor50 (8)
Posted by: mattydred
in: raptor 50
CIMG0052
Posted by: DPS-Dave
in: DPS Dave Genral stuff
Landing Gear 3
Posted by: ROVguy
in: ROVguys Album
Carbon Tail Conversion
Posted by: Coyote
in: Coyote`s Album
* Latest Gallery Items
My Twin Dream
Posted by: Coyote
in: Coyote`s Album
Vortex 285
Posted by: Coyote
in: Coyote`s Album
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
Mini 3D Gimbal on MTD
Posted by: Coyote
in: Coyote`s Album
Matek 405-Wing
Posted by: Coyote
in: Coyote`s Album
Pages: [1] 2 3 ... 14
Author Topic: RSSI Pro Track  (Read 95724 times)
tommyd
  • Flight Lieutenant
  • Offline Offline
RSSI Pro Track
« on: March 15, 2015, 01:39:30 PM »
Hi All
Just a quick post letting you folks know we have a fully field tested 5.8  32 channel RSSI tracker soon to be launched on kickstarter for pre orders it comes with the following features
RSSI signal alone is used for tracking (no on board equipment required)
360 degree continuous rotation
32 including channel scan/select/browse functions
Removable processor chip for software upgrades
1602 LCD display streaming live data (RSSI/Direction and voltage monitoring)
Calibrating & setup functionality
User interface via  5 way navigation and reset buttons
Antenna mount MANUAL tilt lock/beam angle adjustments and can accommodate various antenna designs
Built in low voltage buzzer alarm/LC filter/video amplifier and large battery bay
Video / audio and 12v dc out for powering monitor/goggles
Also works as a lost model finder
Cost will be around  £160 per unit
So just plug in your goggles or monitor select your channel and that's it
more information coming soon
« Last Edit: November 19, 2017, 05:11:51 PM by tommyd »
Logged
  • Tape Apprentice
  • Administrator
  • Offline Offline
    • My New Blog
Re: 5.8ghz RSSI Antenna Tracker
« Reply #1 on: March 16, 2015, 12:06:00 AM »
I have been involved with the field testing of this tracker and have to say I`m impressed with its capabilities. I loved the fact you don't need any specialist equipment on board your plane. If it has a Vtx fitted then your good to go.
The tracking was perfect from it out over several km that we tested it at. It never drifted off, lost communication or had any glitches associated with the other styles of tracker.
If your a Boscam / Skyzone user then this is a brilliant bit of kit.
Logged
  • Air Commodore
  • Offline Offline
« Reply #2 on: March 16, 2015, 11:52:51 AM »
     Are there any plans to make another version that WILL play nice with immersionrc transmitters ??
Logged
g4uvz
  • Wing Commander
  • Offline Offline
  • Webster Flyer
    • webster Flyers
« Reply #3 on: March 16, 2015, 12:09:37 PM »
Yes given that I guess that 70% + use Immersion? this would seem to limit the market...I can see that a specific brand of receiver might be an issue but can't quite see how a transmitter can be a problem ?
A
Logged
  • Tape Apprentice
  • Administrator
  • Offline Offline
    • My New Blog
« Reply #4 on: March 16, 2015, 12:33:10 PM »
I would guess the other way around Adrian, my money would be on Boscam having much more customers due to being much more affordable.
An immersion version would surely drive the price up.
Logged
  • Global Moderator
  • Air Marshal
  • Offline Offline
  • Brought to you by Google
    • My YouTube page
« Reply #5 on: March 16, 2015, 12:53:57 PM »
I was thinking the same thing, but then after I really took things into consideration, I decided it wasn't that much of a big deal.  Here's why -
If I'm plugging my goggles into a tracker to get the video, then my goggles don't care I have an ImmersionRC VRX inside
I know I don't want tracking with every plane quad I put up, I can happily fly 2km skew to skew in any direction and 5km with a 3 turn helical I can put on my Dominator and move my head.
So this only comes up if I wanted to do only 5.8 on longer range for me.  Which means it's about 1 plane currently that could manage that sort of distance.  SO as it stands I'd have to spend another £50 or so on one of those 32 ch VTX's which even after taking into account getting this tracker is still much cheaper than something like an MFD tracker
Of course - on the downside, it's 5.8 only whereas other trackers can work on any system.
swings and roundabouts though
tommyd
  • Flight Lieutenant
  • Offline Offline
« Reply #6 on: March 16, 2015, 01:45:38 PM »
Hi Gents,
Thanks for your posts/comments
During our field tests we found with the immersionrc transmitters although we had signal close in it soon degraded over distance as our system uses the Boscam RX5808 receiver modules we believe there is a conflict between brands that we can not address at this time.
The project was to bring an alternative, affordable and easy to use bit of tech to today's market for 5.8ghz.
Tommy
Logged
  • Air Commodore
  • Offline Offline
« Reply #7 on: March 16, 2015, 02:44:25 PM »
Hi Gents,
Tommy
Thanks for your 'official' reply.
I assume that - if you wanted to produce an immersionrc friendly version - all you would need to change would be the rx receiver.
As an owner of an early version of the Ezuhf tracker system - which I find over-complicated to setup for each fly session, I would welcome an immersionrc version of your tracker.
Considering the changes to produce an immersionrc version appear 'simple' - I would suggest you will be missing extra sales, for little extra cost, if you do not produce an immersionrc compatible version.
Anyone else agree with me ???
Logged
tommyd
  • Flight Lieutenant
  • Offline Offline
« Reply #8 on: March 16, 2015, 03:11:13 PM »
Hi Wgt40w
I see where you are coming from and yes it is possible to convert the system if there was enough interest to make it viable then it is something to consider for sure
Thanks for your input we will look into it
Tommy
Logged
g4uvz
  • Wing Commander
  • Offline Offline
  • Webster Flyer
    • webster Flyers
« Reply #9 on: March 16, 2015, 04:57:30 PM »
WGT 40W.This was my point exactly...I guess that my club must be unusual as we nearly all use the Immersionrc products!
Logged
rob.thomson
  • Group Captain
  • Offline Offline
« Reply #10 on: March 16, 2015, 07:22:18 PM »
During the testing / development of the system I found that immersion compatability is a bit...  funny.
It seems to depend on the vtx models of theirs you use.
All of them work..  some work better..  others..   are just carp.
I guess they use different encoding technology.
So muxh like the skyzone goggles.   It works.. but luck varies!
Rob
Logged
  • Air Commodore
  • Offline Offline
« Reply #11 on: March 16, 2015, 08:05:25 PM »
Hi Wgt40w
Tommy
I would be happy to place a deposit for a first immersionrc version.
Logged
  • Air Commodore
  • Offline Offline
« Reply #12 on: March 17, 2015, 08:03:59 AM »
Have you tried some patch antennas rather than helicals on it?
Logged
tommyd
  • Flight Lieutenant
  • Offline Offline
« Reply #13 on: March 27, 2015, 01:08:34 PM »
Hi Andy,
 Sorry for the delay  and yes we are testing some at the minute for the manufacturing final that should fit in your original shroud design making it nice and compact.
attached is a link to a quick review from RCTV UK
<a href="http://youtu.be/YaQfUIShAOo" target="_blank" class="aeva_link bbc_link new_win">http://youtu.be/YaQfUIShAOo</a>
« Last Edit: March 27, 2015, 03:52:39 PM by Coyote »
Logged
Jake Bullit
  • Group Captain
  • Offline Offline
  • Fly,crash,glue,repeat!
« Reply #14 on: March 27, 2015, 01:27:36 PM »
Looks great,but your missing a big market share if it doesn`t  work with IRC.
Best of luck to you both.
Logged
* Recent Topics
UPDATE: Gatwick drone arrest couple - Dec 2018 by Coyote
[Yesterday at 02:59:41 PM]
Brave New World by Tim Chambers
[July 31, 2020, 02:56:19 PM]
Practicing Acro by FPVSteve
[July 30, 2020, 05:11:47 PM]
I'm (attempting) to make a free FPV quad sim by CurryKitten
[July 29, 2020, 10:10:00 PM]
One motor doesn’t spin, despite throttle position by FPVSteve
[July 29, 2020, 05:00:17 PM]
Mixing it up a bit by luv2rip-fvp
[July 27, 2020, 03:34:58 PM]
Wales Unlocked! by urbanfpv
[July 21, 2020, 06:13:51 PM]
NOOBs first quad... asking for a friend (2020) by Doppelganger
[July 19, 2020, 02:15:05 PM]
Great spot part 3 of 3 by luv2rip-fvp
[July 17, 2020, 09:04:18 PM]
Help No video through my FC by ched
[July 16, 2020, 10:40:55 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
