Opinions on the Ritewing ZII and ZIII and Drak?
Started by Amorgos, April 04, 2015, 11:03:46 PM
Mobius records at 60 fps at 720p. For low down twitchy flying this is perfect IMO. For less risky higher up flying- use the gopro if you want better footage.
I have just changed my launch method on my big wings and it's brilliant. I used to javelin launch then hammer the throttle. But I have used this method on my cap from day one
http://youtu.be/2TWHTzUhXlo
The cap doesn't have much power, so it needs a big throw overhand/overhead. But it works every time.
I tried it this weekend with my bigger, heavier, more powerful wings and it's great. Less risky than the javelin throw for sure. Try this with the zeph. The wings I used it with were if anything heavier than your Z2.
Amorgos
Thanks for this. Good vid. I will try this technique.
So far I have been launching using an underhand grip and yes, you'd probably call it a javelin throw. I found it unpredictable and I've probably failed like 15% of the time which leaves me shit scared of launching it at all!
I'll try playing about with throwing it like that holding the nose end.
Quote from: Amorgos on April 08, 2015, 12:38:20 AM
Full throttle,  damn good throw overhead. Not directly up, perhaps 70 degrees. I cruising wing would stall probably,  but a decent power:weight and it zooms along. As soon as you get your hand on the sticks you can level it off, although it seems to self level pretty much anyway.  I throw with my thumb underneath and fingers on top, with my hand as close to the centre as I can. Others make a real point of having their thumb on top and fingers below, although I don't know why this is favoured by some.
