Cheapest autopilot?
Started by drambuidhe, December 14, 2016, 04:10:10 PM
dp106
I've ordered an FY 41AP Lite to try, hoping it will do the job. If so I can have two of them for the price of one Vector.
From the looks of it you get an airspeed sensor included which is used in the rth and it manages the throttle to fly at the cruise speed you configure. Only issue with this will be if you set the speed to low..
Other thing I like the look of is unless you are below 50m it will rth at your current altitude. Good if you've flown higher than normal over a hill  ::)
drambuidhe
Quote from: dp106 on December 22, 2016, 10:11:02 AM
Two of my flying buddies and myself use the FY41-Lite , and have had great service from them to date.
One's in a Bixler , one in a Penguin and mines in my FX61 wing.
I strongly recommend that you read through the WHOLE FY41-Lite thread on rcgroups. YES- I know its pretty big but I'm glad I did because the instructions are lacking somewhat.
Good luck :D
dp106
Quote from: drambuidhe on December 22, 2016, 08:06:28 PM
Good luck :D
B**gg*r, am I reading it right there is no RSSI input on the autopilot?! Hadn't noticed that, thats a bit of a pain if its not got that  :(
Quote from: Vertigo on December 16, 2016, 10:32:29 PM
Naze with GPS and INav Firmware or PatrikE is awesome.
Its solid far easier than my apm mini
So much you can have MY APM mini and power module for £25.00 delivered
If you would like to try it :-) No GPS though as its on the naze.
Good Luck
Jay
What naze version and GPS are you using? I fancy giving this a try.
drambuidhe
Quote from: dp106 on December 24, 2016, 11:51:26 PM
Rightly or wrongly , I've never had the ability to monitor rssi or been bothered by the lack of it.
If I lose my rc signal it simply turns and comes home. No worries ;)
dp106
Ah, I like having rssi as it warns you you're getting near the limit before you actually go past it
RSSI was only "useful" before RTH systems... now it's just another thing on the screen I hardly look at.
