Lawmate 1.2 problem
Started by Luca_Fly, December 03, 2018, 07:50:58 PM
Luca_Fly
Thank you
In my case you can not see anything  :'(
You are connecting ground as well not just the video wire ?
Luca_Fly
Quote from: Coyote on December 15, 2018, 09:31:38 PM
No  :+
Tomorrow morning I try do it
Luca_Fly
You are my hero, It works!
The Lawmate 1.2gHz problem is not solved, but I wait for the vTx Lawmate to try.
Cool, that proves you have a video signal at least.
Luca_Fly
I suppose the problem could be in the Jeck. I have a DVR that has the video signal at the tip of the jack. ImmersionRC has the video on the third ring of the jack.
I can not find the specifications for the Lawmate 1.2gHz and I do not have the original cables ...
Can anyone tell me where the video signal is and the land on the jack?
This is an example
Have you a multimeter at hand ?
The video should show around 3v but maybe less. Ground can be checked using continuity.
Luca_Fly
I found the ground with the continuity between the case and RCA. The other outputs give 5.6v and 4.2v ... One of the two is video. I continue with the tests.
Inviato dal mio Nexus 5X utilizzando Tapatalk
Luca_Fly
FANTASTIC!!! It works!  ;D
I built the correct cable ... in my groundstation I have 4 differently configured plugs.
The vRx Lawmate 1.2gHz is:
Thank you all.
