My scratchbuilt wing building log. Is this going to fly?
Started by drnikolitsis, August 10, 2012, 08:57:57 AM
drnikolitsis
I have decided to go for this motor O.S. OMA-3820 1200kV motor, a 70A ESC and an Aeronaut CAM 10x6 Folding Prop. This motor is heavier than the one I had installed and wing is probably going to be heavy-tail so I'll carve two new bat bays in the front to balance. Might have to remove some of the balancing led I placed in the nose.Ill take some photos of the progress soon
drnikolitsis
#17
I will have to adapt to the new heavier motor so I decided to go for two batteries in the front. When motor arrives Ill see if I have to add extra weight or remove some from the front. Till new motor arrives ( probably end of this week)I just have to do something to keep me busy, so this is my progress so far.
drnikolitsis
Finally I found some time to put the motor, esc and prop in place.This is what it looks like now....Next you hear from this build log hopefully will be the maiden flight vid :) Cross your fingers :-\
