FPV HUB
Advanced search
News:
Who's Online
  • Dot Guests: 89
  • Dot Hidden: 0
  • Dot Users: 0
* Site Sponsor
* Random Gallery Items
Skywalker vs X8
Posted by: Coyote
in: Coyote`s Album
The Donny Incident!
Posted by: ROVguy
in: ROVguys Album
ce s
Posted by: jakegazzard
in: CE OSD
easy3
Posted by: munkyboy
in: Pauls Stuff
* Latest Gallery Items
My Twin Dream
Posted by: Coyote
in: Coyote`s Album
Vortex 285
Posted by: Coyote
in: Coyote`s Album
Mini Talon Rebuild
Posted by: Coyote
in: Coyote`s Album
Mini 3D Gimbal on MTD
Posted by: Coyote
in: Coyote`s Album
Matek 405-Wing
Posted by: Coyote
in: Coyote`s Album
Pages: 1 [2] 3 4 5
Author Topic: DIY antenna tracker  (Read 56665 times)
Baner
  • Squadron Leader
  • Offline Offline
Re: DIY antenna tracker
« Reply #15 on: June 20, 2013, 10:43:11 AM »
That looks very cool strong and not out of the way pricewise
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #16 on: June 26, 2013, 07:31:18 PM »
Cool, ready for the weekend. Hope the weather is ok!
Logged
Baner
  • Squadron Leader
  • Offline Offline
« Reply #17 on: June 27, 2013, 09:16:05 AM »
I believe anybody to make that and achieve what you've done is fantastic. This is what FPV is all about. Well done. ;)
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #18 on: July 04, 2013, 05:32:32 PM »
Good to hear you got rid of the noise. I might have a spare 2.4g bi quad you can have.
Logged
Kawobei
  • Guest
« Reply #19 on: July 07, 2013, 01:15:34 PM »
Hey Andy,
My arduinos rocked up. Did you have a pic of wiring direct to the gps?
Regards,
Brenton
Logged
Kawobei
  • Guest
« Reply #20 on: July 08, 2013, 12:26:33 AM »
I just got a coupe Pro Mini's like you recomended.
Logged
Kawobei
  • Guest
« Reply #21 on: July 14, 2013, 06:37:46 AM »
Ok i have everything buy my UBOX GPS, for now I have attached GTPA010 Eagletree GPS
I have programmed both boards.
wired the receiver. Now starting transmitter
For the TTL, I gather the TTL is for the STM32F4 and the RS232 is for the FrSky transmitter?
Logged
Kawobei
  • Guest
« Reply #22 on: July 14, 2013, 08:02:25 AM »
Hey Andy,
What are some easy ways to test the serial connections between each board?
I checked there was something coming out of the transmitter by using putty on that serial port but is there a way to use the ST-LINK to show the data coming in from the transmitter?
Regards,
Brenton
Logged
Kawobei
  • Guest
« Reply #23 on: July 14, 2013, 01:57:47 PM »
I can use either operating system, I have made a Ubuntu VM to put the arduino code on.
I think the GPS is working I got the fast flashes after a bit (after I swapped rx and tx on the gps plug, I didn't know which was which)
for the receiver do I need to have the arduino plugged into a analogue or digital telemetry port?
Hi Brenton,
Good question. Your GPS unit sounds close to whats in the code at the moment, so if we are lucky it might even work as is!
You can see if the airborne part is working by looking at the little green LED on the Arduino once switched on.
Bear in mind you should do this outside in a nice open area so the GPS has a chance to get a lock.
On initial startup the Arduino Pro Mini LED blinks 6 times rapidly .
After a 1/2 sec delay blinks 5 times more slowly.
After a 1/2 sec dealy again  continues blinking very slowly.
It does that until the GPS achieves satellite lock on 5 satellites
Then it blinks faster with a shorter on period so giving a heartbeat pulse .
I've done a Youtube video of the startup sequence.
DIY Antenna tracker airborne GPS unit startup sequence
Bit blurry sorry about that!
If you get to the blinking slowly part and after (say) 10 miins it doesnt change to the heartbeat then it will mean that The unit isnt understanding the GPS.
Anyway meanwhile I'm now looking at basing the GPS code on the Ardupilot code rather than rolling my own. They seem to cater for several different GPS units. (I hope also to make an OSD based on the MinimOSD hardware. It'll be necessary to solder onto one of the chip pins to get data output but that isnt impossible.)
EDIT: Actually the following isnt necessary - you can see from the LEDS on the Discovery board - see my next post...
As for testing the Ground Side from the Transmitter, the easiest way is to get a RS232 to usb cable. However if you have the RS232 to TTL cable then you can connect the TTL side of that to your FTDI cable (which I assume you have to program the Arduino).
The data comes out in binary format so will look like goblydy gook. I have written an app to decipher it..
https://github.com/kwikius/frsky_data
 but its written for Linux. I'll have to get around to rewriting it for Windows ASAP! ( assuming your OS is Windows?)
Anyway First to see if you are getting the heartbeat pulse indicating the airborne part is reading the GPS correctly.  I'll see what I can do to port the ground side App to Windows. Shouldnt be too much. Just rewrite the serial port code I think!
Thank for persevering with it  :)
Logged
Kawobei
  • Guest
« Reply #24 on: July 14, 2013, 02:24:55 PM »
Oh I did get the faster flashing light now after some moving around its not speeding up anymore.
This little arduino gets hot are they meant to?
I did have trouble getting the STM32 libraries setup in Ubuntu im having gcc compiling errors but ill work through them (think ill have to start again)
(I am breaking up posts to get my count up so I can pm)
Logged
Kawobei
  • Guest
« Reply #25 on: July 14, 2013, 02:28:34 PM »
Did you have the design files for the tracker that you made in freeCAD up anywhere?
Logged
  • Air Vice-Marshal
  • Offline Offline
  • November Video Of The Month Winner
« Reply #26 on: July 22, 2013, 03:27:07 PM »
Tell you what would be a good project.. Try and replicate the EagleEyes protocol, I bet you could sell loads of those as people could buy an EE ground-station to do the tracking/diversity..
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #27 on: July 22, 2013, 06:08:12 PM »
This is the problem, there is no public spec :( the EagleEyes Ground Station is a great piece of hardware at a bargain price but you have to have the whole EagleTree setup to use it :(
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #28 on: January 21, 2014, 08:01:56 PM »
Well that looked like it worked well.
Logged
  • Air Vice-Marshal
  • Offline Offline
« Reply #29 on: January 22, 2014, 07:39:03 PM »
Cheers, will do
Logged
Pages: 1 [2] 3 4 5
* Recent Topics
Drone and model aircraft registration - latest. by BigT
[Yesterday at 07:34:22 PM]
E.T.s Flywoo Mr Croc 5 inch Quad Build...Long Range? by English Turbines
[Yesterday at 05:11:44 PM]
I met up with my friend of 42 years! by luv2rip-fvp
[November 13, 2019, 11:56:26 PM]
Pilot Competency Exemptions by BigT
[November 10, 2019, 12:55:44 AM]
Creality Ender Series by Coyote
[November 09, 2019, 03:39:17 PM]
Withdrawal by Jakalas
[November 08, 2019, 12:18:29 PM]
Toothpick class - slow for garden use? by ched
[November 07, 2019, 09:33:13 PM]
Finally! by luv2rip-fvp
[November 05, 2019, 02:24:37 AM]
Some indoor whopping by luv2rip-fvp
[November 02, 2019, 12:47:04 PM]
220mph Proximity by omegooliebird
[October 31, 2019, 01:50:54 PM]
* Keywords
fpvhub  fpv hub
* Disclaimer
