Planes => Gliders and Scale Planes => Topic started by: chris-s on January 09, 2014, 08:25:13 PM
Title: FPV'ing a Durafly Corsair
Post by: chris-s on January 09, 2014, 08:25:13 PM
I got one of these for Christmas and was thinking about a simple fpv job on it, but it's got a pretty small cockpit so I was wondering whether one of the 'extended' 808 #16 cameras would be good enough to fly with?
(http://i127.photobucket.com/albums/p132/chrisspb/th_6d227587240b4cdb8532d287af679ad1_zpsd837df1c.jpg) (http://s127.photobucket.com/albums/p132/chrisspb/?action=view&current=6d227587240b4cdb8532d287af679ad1_zpsd837df1c.jpg)
I thought I could put the camera up into e cockpit and then run the lead to the rest of the 808 and vtx mounted in the battery cover. I could the get a second replacement cover and leave as standard for LOS flight.
Would it work?
Chris
Title: Re: FPV'ing a Durafly Corsair
Post by: Coyote on January 09, 2014, 09:07:14 PM
With that limited space I would go for a mini cam, the wide HD view of the 808 would be mostly wasted
Post by: chris-s on January 09, 2014, 11:12:31 PM
Can you point me in the direction of a 'mini cam'?
I know there is a little turnigy one, http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=34059, (http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=34059,) but the specs don't make it seem much good.
Then there is the tiny nano camera from firstpv, http://www.firstpersonview.co.uk/cameras/2g-nano-520tvl-camera (http://www.firstpersonview.co.uk/cameras/2g-nano-520tvl-camera) but no Ira how good it is.
This is the smallest camera I've got http://www.surveilzone.com/sony-super-had-ccd-700tvl-ultra-mini-fpv-camera-2.8mm-lens-hs1150 (http://www.surveilzone.com/sony-super-had-ccd-700tvl-ultra-mini-fpv-camera-2.8mm-lens-hs1150) but it's going to be too big.
Chris
Post by: Coyote on January 09, 2014, 11:14:50 PM
If the surveilzone one is going to be too big then your looking at the 2g Nano like you linked from firstpersonview.co.uk Chris
Post by: chris-s on January 09, 2014, 11:18:09 PM
Ta.
Post by: Dizzy on January 09, 2014, 11:40:17 PM
Quote from: Coyote on January 09, 2014, 11:14:50 PM
Chris i found the 2g camera from firstpersonview is sweet its lacking compared with a wdr but i flew my small spit with one but it needs good bright weather i found otherwise the picture was a little on the dark side
Post by: chris-s on February 09, 2014, 01:20:47 PM
A bit of progress on the cockpit front....
(http://i127.photobucket.com/albums/p132/chrisspb/FPV/7DAE7145-C553-4EA5-8758-26A41830527E_zpszlzok0ds.jpg)
Interchangeable cockpits, so I can fly regular LOS or fpv. I plan to fit the vtx just ahead of the canopy and run the skew back thru the cockpit and then rotate up 90 degrees so it sits just behind the canopy.
I cut out the clear parts leaving the frame with a hot scalpel blade which made a neat job of it.
The camera will be on a pan, but not sure whether I can leave it in the head as you  see above or if it will need to be mounted further back which means it will have to be pilotless.
I decided to try the 808#16 with one of those extended 120degree lenses, but didn't realise that what I had actually  ordered was a #11 lense and it don't work with the #16 camera so I'm now waiting on some other bits.
The biggest problem I've had is getting side tracked and detailing it up a bit, I blame it on idle thumbs and crap weather...
(http://i127.photobucket.com/albums/p132/chrisspb/Planes/9197E60F-E4F3-4A2C-A6CB-62E9E901C409_zps54jlqhml.jpg)
All the 'wing clutter' is mag-mounted so can easily be removed.
Chris
Post by: Jake Bullit on February 09, 2014, 01:58:52 PM
Nice :)
You gonna name the pilot Cyclops? :D
Post by: Brod on February 09, 2014, 02:03:17 PM
looking good,cant beat a bit of scale ;)
Post by: Brucey on February 09, 2014, 02:33:48 PM
Looks great, I'm tempted to buy a durably spitfire to do the same. Like the tip on the hot scalpel blade.
Post by: lrosm on February 14, 2014, 11:58:00 PM
looking good.
Brucey let me know how it goes, i have a spitfire that I have yet to fly.  once i have it mastered i would love to FPV it, not for me to fly but for "co pilot" i.e. my son to be immersed in the flight with me from the cockpit.
exactly what TX would you use?  i hazard a guess something very small, light & unobtrusive (also would need it comparable with my fatshark googles)
cheers,
lrosm
Post by: Western on February 15, 2014, 12:16:06 AM
The pilot looks like a minion from the Despicable Me films.
Title: Re: FPV'ing a Durafly Corsair - camera test
Post by: chris-s on February 22, 2014, 05:21:37 PM
So, camera and pilot all fitted calling for a quick test on the bench....
http://youtu.be/udBn98SRxQk (http://youtu.be/udBn98SRxQk)
... the fpv looks like it will be interesting, supposed to be a 120 degree lens.
Chris
Post by: micarus on February 22, 2014, 05:58:48 PM
Lovely installation ! very neat , looking forward to the video.
             Cheers  MIKE.
Post by: chris-s on February 22, 2014, 11:49:45 PM
I think it will definitely need a few LOS flights first. As for the scale stuff, I got a bit carried away with it, blame it on the bad weather leading to too much time in the workshop.
I thought the fixed tailwheel was letting it down so modded the existing one into a retractable...
http://youtu.be/JEc0Hh3ISNE (http://youtu.be/JEc0Hh3ISNE)
Chris
Post by: chris-s on April 04, 2014, 03:37:12 PM
Well, I finally got chance to maiden the Corsair at lunchtime today, bit breezy but warm and sunny.
OK, so this was non-fpv maiden, flies great, way too much elevator on first flight but got it dialled down for three more flights and with the wind it just floats in for the gentlest belly landing. BUT, there is no way I'm going to FPV it, at least not yet, way too quick, responsive, tricky to take-off from grass without nosing over and looks too nice. Maybe when I've flown it a bit more and the grass is shorter and much less wind or perhaps I should just get something slower for fpv'ing scale style.
Chris
