I have just ordered a falcon evo but would like a small fpv tough wing to practice with.
What would people recommend.
The Evo is pretty strong, I haven't managed to kill my latest one yet even going straight in at 60mph at the last Mad Dogs.
If you want to look after your Hornet and get something cheap and strong to bash about though, the Hornet is a great laugh.
http://flyingwings.co.uk/fpv-uav/fpv-wings/hornet-mini-fpv-racing-wing.html (http://flyingwings.co.uk/fpv-uav/fpv-wings/hornet-mini-fpv-racing-wing.html)
So are you saying hornets are good.
Hornets are good, and lots of fun. It's hard to hurt them as they weigh practically nothing.
I'd get a Falcon Evo, but despite my original Falcon crashing and smashing in all ways and being at least 60% glue, it comes back together and still flies lovely.
I would highly recommend a wing wing to practise with, I fly mine like a mini quad(stupidly) and it's tough as tough could be, it is a bit beaten up now but the only thing I've ever broken is the canopy(equipment cover) and that was just a splodge of hotglue to fix. It's been crashed into trees, nose dived straight in to a field and all sorts lol. With a 1400kv, 6x5prop on 1300mAh 3s carrying a mobius and FPV cam and VTX, it goes really well, perhaps 7 minutes flying silly, 10 just chilling.
A video to show how it flys...
http://youtu.be/4ZVb_VO7cgY (http://youtu.be/4ZVb_VO7cgY)
Could you send me a link to the wing your on about thanks
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=25663 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=25663) :)
Told you wrong about the motor though in the previous post, it's the 2200kv one you want not 1400 ;) http://www.hobbyking.com/hobbyking/store/__28403__Turnigy_D2826_6_2200kv_Outrunner_Motor_UK_Warehouse_.html (http://www.hobbyking.com/hobbyking/store/__28403__Turnigy_D2826_6_2200kv_Outrunner_Motor_UK_Warehouse_.html)
Any chance you could post some pictures of where you put your fpv etc
(http://i19.photobucket.com/albums/b178/johnnyjtaylor/Mobile%20Uploads/20150509_162834_zpsw5wj27rn.jpg) (http://s19.photobucket.com/user/johnnyjtaylor/media/Mobile%20Uploads/20150509_162834_zpsw5wj27rn.jpg.html)
This was when I first did it, I just cut a slot in the canopy for the board cam and 3d printed a little 'table' for the mobius(if you get one and don't have access to a printer I could do you one for postage). Later I cut out a small piece of foam out of the nose and put a fatshark cam in(just because I don't like the way those board cameras transition from light to dark lol)
Here's how it compares to the Falcon Evo.
(http://i19.photobucket.com/albums/b178/johnnyjtaylor/Mobile%20Uploads/20160505_092916_zpshahihz5e.jpg) (http://s19.photobucket.com/user/johnnyjtaylor/media/Mobile%20Uploads/20160505_092916_zpshahihz5e.jpg.html)
Here's another option
http://www.hobbyking.com/hobbyking/store/__82603__HobbyKing_8482_SkyRay_Flying_Wing_FPV_Model_1213mm_EPO_PNP_UK_Warehouse_.html (http://www.hobbyking.com/hobbyking/store/__82603__HobbyKing_8482_SkyRay_Flying_Wing_FPV_Model_1213mm_EPO_PNP_UK_Warehouse_.html)
(http://www.hobbyking.com/hobbyking/store/catalog/82600s(3).jpg)
This is the PNF version that comes with all the flight electronics... 2200kv motor, servos, ESC. no laminating, no building ply middle sections, no cutting blank foam for servos or gluing on motor mounts. Apparently as long as you've got a RX and LiPo to go in it, it's ready to fly in under 20 minutes out of the box.
At this price I'd say it's ideal for practising... you may not even want a Falcon EVO afterwards if it meets your requirements.
Thanks for all the info.
By the way, since my post about the skyray, mines just turned up and I've already built it :)
How did it take to build
About 30 mins including the fpv gear
Can you post a picture with fpv installed.
Isnt it better to get a wing made of epp rather than epo as alot stronger.
Sure, just got in from taking my Daughter to swimming lessons...
(https://dl.dropboxusercontent.com/u/8259957/FPV/SkyRay/SR01.jpg)
(https://dl.dropboxusercontent.com/u/8259957/FPV/SkyRay/SR02.jpg)
(https://dl.dropboxusercontent.com/u/8259957/FPV/SkyRay/SR04.jpg)
Looks really nice,Loads of room
Hobbykings has the price mixed up the pnp is cheaper than the kit.
yeah, went together really quick lol... surprised myself.
I commented on your thread because I had ordered this very plane... then literally about 10 minutes later the doorbell rang and it was the postie delivering it :)
Quote from: mrorange26 on May 05, 2016, 07:16:55 PM
It all depends.
EPO is moulded so the designers have more flexibility when designing the thing, also you don't need to laminate EPO as it's stiff enough already and the surfaces are nice and smooth.
EPP is just block foam and is cut to shape with hot wire to create the airfoil shape. EPP wings don't generally differ that much in terms of basic design, even the blunt nose ones are all pretty much the same basic concept. Once you get to around the 1m wingspan mark, EPP really needs to be laminated to add strength and rigidity.
Quote from: mrorange26 on May 05, 2016, 07:57:33 PM
I know :) :) I bagged it as soon as I noticed that :) :)
The 30 minute build time even included me changing out their motor and ESC for a SunnySky 1400kv motor with 8x5 prop, and a 4S capable 40A ESC.
Very nice.
with the dome nose, but my runcam2 hd hasn't arrived yet, so I'll be sticking with the foam nose for now and I'll be taping them on too... don't trust the magnets.
(https://dl.dropboxusercontent.com/u/8259957/FPV/SkyRay/SR11.jpg)
What video transmitter size do you use
if it's your first wing then the smallest lightest thing possible. Hornet. Maybe the HK tek sumo.
I fly my HK Bonsai every time I go out - absolutely love the little thing!
Just about unbreakable, dead easy to launch, vertical climb, pretty aerobatic too, and land it in your lap.
;D
Do you have fpv on it
Yes, Sony HADII board cam on the front, lightweight 200mW 5.8G TX on top over the COG.
2S 950mAH Lipo gives 8 mins of cruising or 5 mins of aerobatic hooning.
Weighs 220 grams AUW.
Could you send me a picture of your setup
Will do this eve when I'm home from work.
And it's got too dark to fly....
:P
ok thanks
OK well here it is in all it's glory - which isn't much TBH!
It's a scruffy little bodged together turd that was never planned, it just sort of happened with Velcro and hot glue.
But in terms of smiles per quid spent, I like it...
Dynamic 12A ESC - the original 6A one caught fire...
Lemon LM0034 Diversity 2.4G receiver
FOXEER / Sony HS1177 CCD camera.
FX799T 200mW VTX with random skew RHCP thingy antenna.
HK / Turnigy Aerodrive 2118 3100 KV motor.
Cheap Gemfan 5040 prop.
Like I said, I'm sure there's a lot of alternatives recommended by folks on here that will perform better - I don't know - but this works for me and brings smiles every flight...
(http://s32.postimg.org/fx9l34sn5/060520163934.jpg) (http://postimg.org/image/fx9l34sn5/)
(http://s32.postimg.org/53f3xwsg1/060520163933.jpg) (http://postimg.org/image/53f3xwsg1/)
Good luck & have fun !
Thanks for posting all helps to deciding what I want to get.
What battery do you use
These - 8 mins floating, 5 mins T.W.O. hooning...
http://www.hobbyking.co.uk/hobbyking/store/__20389__Turnigy_nano_tech_950mah_3S_25_50C_Lipo_Pack.html (http://www.hobbyking.co.uk/hobbyking/store/__20389__Turnigy_nano_tech_950mah_3S_25_50C_Lipo_Pack.html)
T
I would say a Hornet from personal experience. I had the first style Falcon that I ragged to death, and now have a Falcon EVO, but in the meantime got hold of a Hornet from Flyingwings. Jimbo19, also on here has ahd avery little RC flying and yesterday maidened his Hornet. The wind was probably too high to be far, but the Hornet doesnt seem to worry too much. These things are such a hoot to fly and can easily get 15 minutes flight time from a 800mah battery if just pootling around.
See on-board footage from yesterday - around 4:10 onwards, following a Wot4 E in on a Landing and right at the end of the Vid, our attempt at a Hornet Syncro Landing.. Jim may pop on later, but he was really anxious about the maiden, but got on really well :)
! No longer available (http://www.youtube.com/watch?v=5gl8QiAgipg#)
And my Hornet, all built up.
(http://img.photobucket.com/albums/v477/simfin/20160402_145700_zpsoyod8fwo.jpg) (http://smg.photobucket.com/user/simfin/media/20160402_145700_zpsoyod8fwo.jpg.html)
Been having fun with my light weight Z84 setup,easy to fly and nearly twenty minutes on a knackered old 3s
http://youtu.be/m8SisvDP8kI
All look so good,So different to my 250 quad racers.Decisions decisions.
What battery do you use on a hornet.
Honestly get a Hornet so much fun and in my limited experience very easy to fly - it has given me loads of confidence and would buy another in a heartbeat if I trashed this one
As Karlak said we were flying for 15 mins yesterday on one 800mah 3s battery !!
Any particular c rating
20c - cheap as chips
http://www.hobbyking.com/hobbyking/store/__26722__Turnigy_800mAh_3S_20C_Lipo_Pack_E_flight_Compatible_EFLB0995_UK_Warehouse_.html (http://www.hobbyking.com/hobbyking/store/__26722__Turnigy_800mAh_3S_20C_Lipo_Pack_E_flight_Compatible_EFLB0995_UK_Warehouse_.html)
Rob also sells them with the kits , so just get all from Rob at Flying Wings - if that's what you go for
Whats the build time on it.
Here you go one of Flyingwings models which Rob had refurbed for me to practice with, flew it twice got straight back into flying wings again ( had a few of Robs over the years ) and then moved straight on to Falcon and Vent !!
Can't fault them have helped me enormously getting going in FPV !! Although very addictive :o
(http://s32.postimg.org/4xlfyx5fl/image.jpg) (http://postimg.org/image/4xlfyx5fl/)
(http://s32.postimg.org/deky9ua4h/image.jpg) (http://postimg.org/image/deky9ua4h/)
Quote from: mrorange26 on May 07, 2016, 06:24:34 PM
Like Jim would know ;)
He dropped it round here on the Wednesday night and picked it up Friday. Just waiting for the UHU Por glue to dry is the limiting factor.
Build time for me was 2 of the 800mah Batteries :P
Nice what size video transmitters do you use on them also would a frsky d4r be ok on them.
Yep using d4r-ii on them and a 600mw mini vtx .............errr i mean 25mw ;)
ok thanks
