Rob's Skywalker - 1.9
Started by rob.thomson, March 28, 2014, 12:19:08 AM
rob.thomson
Agreed!
Can't believe how much under camber the 1.9 Skywalker has.    It should carry a shed load of weight!
rob.thomson
And the bird is complete!
rob.thomson
Picture may work this time!
Western
Correct about the wing. I got in a thermal on Sunday and went from 100m to 400m in a heart beat. Only issue was not enough down elevator to slow down the lift so I had to power out down wind. Did you go with the 4s set up?  I am thinking of cutting in flaps.
rob.thomson
I have set it so I can use 4 or 3 cell.   Will see which I prefer!
I have been in two minds on the flaps.  They just add more complexity - and need for another servo channel!
You could have gotten out the thermal by doing the age old - full up - full rudder
Two or three quick spirals :-)
Actually I rather enjoyed the ride! Did you have any problems getting the elevator free?  In the end I cut mine off and hinged it with Robart's and used blenderm  tape to seal the gap.  I also braced the tail with 2 CF struts to eliminate the "wobbles".  I changed the stock motor as it was noisy and had a lot of end float for this one http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=36820.  On 4s it pulls 30 amps on full throttle but has twice the watts of the stock motor.  I use this motor a lot on Autogyros with a 13 x 6 prop so with a 9 x 6 it is under no stress.  Actually flying wise I prefer the 168, it seems better balanced  with the longer ailerons and flat bottom wing.  The surprising flight characteristic is the tendency to tip stall, but as you are an experienced large glider man you will know why that happens and be prepared for it.
rob.thomson
Mine wasntje base kit, so went for my own motors, ESC and prop combo.
The whole model (all the white) is skinned with glass tape.  No chance of any wobbles :)
My hinges are all stock, with some minor mods.
What I do is to flex it until if moves freely, then run a small amount of silicon down the hinge line to help keep things secure.
Hope to fly it in the next few says.  Maybe tonight if I am lucky!
I've just had to order one, I hope you're satisfied!
rob.thomson
Its my second one :)
My first I nukes through pure stupidity!  This one I ordered the same day I destroyed the first.
micarus
Quote from: rob.thomson on April 16, 2014, 04:19:56 PM
Can I ask where you got your Skywalker Rob as I wrote mine off last year and fancy the 1.9 like yours but don't order from China anymore as I have been bitten twice now with import tax and Parcelfarce costs.
U K branch of Hobbyking don't seem to have that model .
Looks very nice B.T.W. Bud.
              Cheers  MIKE. :D
Got mine from Hk. Took 7 days came via ups no duty asked. Guess I got lucky this time. Thing is it had bevrc stickers in the kit!
rob.thomson
I ordered mine in AliExpress
Shipped with DHL so I could guarantee tracking off the 'unknown'
micarus
Quote from: BigT on April 17, 2014, 09:08:55 AM
I don't have that type of luck M8 :o
                     MIKE.
micarus
Quote from: rob.thomson on April 17, 2014, 10:53:50 AM
Thanks Rob.
                      MIKE. ;D
