keychain camera live out + card recorded vid
Started by dirtyharry, January 18, 2013, 07:33:18 PM
dirtyharry
Bevolution wing with 808#16 keychain camera with wide lens + live vid out.
first go at sony vega video software , like the picture in picture thingy , also did a reverse flight/ slo mo on the crash at the end . 3 turn helical doesn't like it when your right behind it doooh.
rothie snow jan 2013
littleimp
Un-believable video quality for how much those video out cams are. Was toying with the idea of getting opne of these instead of risking expensive gopro.
dirtyharry
I like it as its just so compact , theres a 5v ubec running this and the transmitter. I could probably run the OSD off it as well as theres a 5v regulator on it.
Could still do with some of the settings messed around with as its a bit dark , and the focus isn't 100%  but for £33 including the memory card  i'm happy with it.
Rudeboy
wow the picture quality is excellent on these wee cams, impressed!!
My YouTube Channel
[url=http:
Flyn
Firmware updates & tools here for any who've not fund it.
http://www.mytempfiles.info/nr16/index.html
On the 808 16 v2 lens D the wide angle lens' focus can be adjusted just by turning the lens by screwing in or unscrewing it, mine needed changing too, it was set for 3ft - not too good.
Use the vid out to help set it.
Flyboysee
Great ending - hpe it's all okay! I have the 808#16 bought about a year ago. Can you post a link for the wide angle lens? How does it fit on?
This is not a game anymore!
www.youtube.com/flyboysee
Flyn
It's the v2 cam mate the older versions with the pin hole won't fit, you'd need to change the cam & lens, housing & rewire
dirtyharry
Quote from: Flyboysee on January 18, 2013, 09:48:36 PM
. The wings still good , epp + 3m cross weave tape = almost indestructible. As flyn said it all came as one unit , bought mine 6 months ago from here:-
http://www.ebay.co.uk/itm/Mini-DVR-808-16-V2-Lens-D-Key-Chain-Micro-Camera-HD-720P-Pocket-Camcorder-8GB-/150870367029?pt=US_Surveillance_Digital_Video_Recorders_Cards&hash=item2320931b35
but if you want to drill out the housing they also sell the camera , no idea if it will work but can't see why not.
http://www.ebay.co.uk/itm/Lens-D-Module-120-for-808-16-HD-Car-Key-Camera-Pocket-Camcorder-720P-Mini-DV-/181010633924?pt=US_Surveillance_Digital_Video_Recorders_Cards&hash=item2a251314c4
and the best stuff for attaching it is 3m dual lock , its expensive for what it is but it works , kind of like lego velcro it locks it in place
http://www.ebay.co.uk/itm/3M-DUAL-LOCK-TAPE-5X-STRONGER-THAN-VELCRO-25MMx-25MM-8-PADS-/310412371468?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item484604e60c
dirtyharry
should have added you need to smear the camera with superglue before trying to glue/stick anything onto it as the plastic is some kind of weird non-stick surface.
Cool video, I think its the first I`ve seen of live out from a fob for flying on. Looks like it coped really well :)
Jake Bullit
They fit nicely into an empty tictac box. ;)
Sent from my HTC HD2
littleimp
psyvision
#12
Finally got out and maidened my TBS Disco with this 808 recording (can't afford a GoPro at the moment). No FPV gear either.  Definitely need to sort out a mount that makes it shake less, using the included velcro at the moment.
First Onboard Quadcopter Video
Jake Bullit
I have the V2 and can`t get the focus any sharper than this:
(Disco footage)
CC3D DISCO TARLETON-FOCUS ISSUE
I`ve twiddled and tweaked it,my old number 3? was better.
Dizzy
Quote from: Jake Bullit on February 22, 2013, 10:48:44 AM
(Disco footage)
My 16 was the same it was never perfect but now somebody else (owns it with out my permission) i left it with a n011 and some cards on my parcel shelf whilst flying  :(
Think its worth getting another one though there brill for the price :)
dizzy
Los slope
