CNC Routing G10 or Carbon Fibre
Started by plingboot, January 22, 2013, 05:35:44 PM
plingboot
Does anyone know where (in the UK) i can get some simple parts cut from either 2mm G10 or 2mm carbon fibre sheet?
...at a reasonable cost.
I've drawn up the parts and can supply dxf files and are no bigger than 150mm x 150mm
I'm almost tempted to look into buying a table top router, but suspect that is a maze of hardware/software/file-type bear traps.
hazardpro
I'd be interested on this too! I have some Perspex bits that need routing...
Teamftp
Do you have a sample you could send me.
Could try it in the laser cutter. Fairly sure it will cut it out ok but would like to try it first.
Hazardpro....
What do you need doing. Gots lots of acrylic and a laser cutter that loves it!!!
Teamftp
Oh and do have a flat bed router if the laser cutter is not man enough!!!
hazardpro
Yey :)
Can I have your email please and ill email you the cad file.
Many thanks
Doug
Teamftp
Quote from: hazardpro on January 22, 2013, 07:19:50 PM
Yey :)
Many thanks
Doug
PM sent. Make sure it is a DXF file if possible.
Cheers.
stef1
hi all
have tried to cut carbon fibre on my laser cutter and it just makes a mess
the laser just burns the edge and it just turns to dust
makes a good light show as the carbon burns
Teamftp
Well that's sounds fun at least!!
Got a huge CNC router if needs be that has a 2mm bit for some nice close stuff.
hazardpro
Cheers.
[/quote]
Email sent! Thank you  :D
Doug
Teamftp
Can you confirm the centre to centre of the holes across.
I get approx 53mm
I have 3mm acrylic in most colours if you have a preference?? 2mm is a bit to flimsy for most applications.
Should be able to get it cut tomorrow.
Will be about £3.00 to cover postage and Jiffy bag. Will cost nowt to cut as I will slip it on some waste.
hazardpro
Wow that would be awesome thanks!
53mm is fine (its not dependant on anything).
If Paypal is ok then ping me a payment request and ill send you some dollar!
Thanks again!
PS so thats £6 total? (I need two of them if poss)..
Doug
Teamftp
Nah just £3.00!!!
They will both fit in a bag together.
hazardpro
Quote from: Teamftp on January 22, 2013, 09:03:36 PM
Nah just £3.00!!!
Can I be cheeky (will happily pay!) - 1 more plate, 3mm is fine.. its just a slightly different shape. I can get the DXF to you first thing in the morning?
Hope thats ok! Really appreciated it :)
plingboot
G10 or CF sheet will definitely need to be routed rather than lasered  :)
I don't have any G10 on hand but can i send you my dxf files to check?
If they're ok for use with your routing system i'll source some G10/carbon fibre and organise getting it to you.
I've been using razorlab to prototype these in perspex, but it's not the ideal material and they are a bit pricey.
Teamftp
Sweet I will send you a PM and then you can send me the DXF files.
I did not think the carbon would cut on the laser... Never mind we have the beast below to sort it!!
These have been laser cut this morning.
