Coyote`s Eazystar Build
Started by Coyote, October 18, 2010, 08:50:31 PM
Jay28
Quote from: Coyote on October 20, 2010, 10:17:46 PM
I dont need the tail to come off
Especially during flight!!!  :o The builds looking good Ian, can't wait to see the finished article.  ;)
Waikawa
Interesting to see the remark about magnetic fields affecting the vtx.  What sort of effect?  wobbly lines, loss of signal?
Badlands
Im not sure what effects if any yet, but im trying to keep the srong magnetic fields away from the delicate and sensetive trandsmitter and camera. Hopefully nothing will show up, im testing the camera tomorrow to see if anythings effecting that
Cheers Martin, hopefully get a load more done tomorrow :)
Oh goody :)
Just got in from work to find a lovely new 10mw Vtx thanks to Simon
Servo`s have arrived, but only for one plane no both :(
ESC`s for both planes turned up
Two lovely motors too :)
1x 2200 Black Mantis for my LOS Ez and the outrunner for this build :
Black Mantis, a great FPV EZ choice of motor :
I know its not to do with this build but damn its sexy lol
2212-06 28A 2200KV SP
And my transmitter, so guess i have a bit of spare time tonight for myself so lets start building :)
mark1975
thats one sexy motor looks the bees knees.................
https://plus.goo
Ok quick update :
First the camera pod, because pan servos tend to be first effected and need to be kept super still i added a ferrite ring to the servo lead. 5 wraps rounds enough to work effectivly
Next thing i wanted was to mount the vtx and EZOSD so they were accessable so i could adjust the Osd without ripping everything to bits or change channels on the vtx. Here`s how ive mounted them :
The height was govened by the antenna height i wanted and cable connectors having to clear the lipo. Also there would be a birds nest of wires so i donned the soldering iron to simplify the wiring and improving clearance :
Next on the list was to mount the current sensor to the EZ. By doing this it means fitting the pod is a three wire affair, all connectors are locking apart from the servo connection to pan servo.
I mounted the current sensor, tapped into it and got the feeds for the RSSI reading and display toggle input. RSSI on a UHF receiver might seem pointless but i think that monitoring it would let me know of any problems and might save an accident.
I then fitted the elevator servo wire, the pan servo wire and ailerons. Then spent a bit of time making it as neat as i possibly could :)
mark1975
hey looking good ian looking very neat and tidy well laid out aswell ..really looking forward to seeing this take to the skies ..
https://plus.goo
RSSI Is Receiver Signal Strength Indication.
All receivers have this pin on board, you tap onto the pin and the Osd reads the voltage off it. The voltage increases or decreases as signal gets stronger or weaker. You can program the scale on the EZOSD to let you know when your receivers getting to its max range before failsafes kick in.
The problem with using it on a UFH system is you would have to be 20-30km away for it to be any use. :)
So another bit later and all the electronics are in now.
Even though theres a lot of kit fitted im quite happy it look so neat
I still need to fit the motor mount for the outrunner and figure out my own version of a gopro mount. I want to keep weight to a minimum so something basic but practical and safe is the order
Bit of thinking time tonight and im sure ill have it sussed :)
Ok time has past and i turned my thinking to a better way of keeping my pod on my EZ.
I wanted quick access, practical, easy to do :)
I came up with this :
Cut down mainshafts from a heli, drill hole through fitted pod into easy fuse, fill holes with glue and fit the shafts till the holes were the height of the pod. I then cut two hairclips and attached some wire to them, so i dont lose them in the field and fitted them.
I then pushed the shafts down so they make the pod fit tight and then left the glue to go off to get the heights of the shafts correct
The result :
Rock solid, the pods going nowhere fast :)
Jay28
Quote from: Coyote on October 21, 2010, 09:27:03 PM
This is the kinda problem I like!  :D
Love the pod clips idea Ian, good one!
Are you mounting the ESC on the inside of the bird and if so, are you worried about airflow/cooling?
Yes my kind of problem too :)
Cheers the pod wont go anwhere now.
Excellent question, yes ive mounted the ESC inside to keep its looks. Becasue im mountng an outrunner the cooling duct at the front of the motor pod can be utilized for ESC cooling.
I have made a piece of depren, glued it in place which blockes the air from exiting from the rear and chanelling it down the duct ive cut
The air enters the top, goes down the channel into the ESC section, and the blue arrow shows channels cut in the sides where it escapes
Normally you could get away with no cooling if you picked a high enough ESC but ive added these because the motor is power hungry :)
mark1975
brilliant ian shes looking very nice and some nice little clever ideas alot can be learnt from this build ..me included
https://plus.goo
