Main Menu
LC Filter
Started by Coyote, December 13, 2010, 07:11:51 PM
Pasty
I like the recycle idea... off to the loft for me! :)
Have you tried them yet?
Badlands
#31
Yes - fitted one to my GPS unit (torroid only).
Works really well, sometimes i was waiting 20 mins to get a GPS lock - now from cold i have GPS lock in 90 seconds.
Ive added one to my Steathwing & will report back the results once its finished.
It's all a lot of simple tricks and nonsense...
hpmc
thanks for that coyote i made one and it has improved my video,i will fit one on all now
Most welcome, they are really effective arnt they :)
Running the whole system from one lipo is in my oppinion better than two. Once its filtered if needed its fine.
I got lost a bit with the rest, do you have diagrams of the more complex filters ? If so then yes please do post them up :)
Which diagram do you want me to post, the one for your system ?
ak47
Hi all, ive deceided to put an LC filter in my easystar set up that uses an ezosd.
I will put the ferrite ring in then the capacitor on the power / video in lead. Is there any point adding a ferrite ring on the video out lead to the camera?
Ant
MarekM
Quote from: Coyote on April 01, 2011, 10:20:15 PM
Hi,
better will be to use 10-47 nF in place of last 100 uF. Diode - any Schottky type switching diode.
Other idea - in place of ferrite ring - put 10 uH axial inductor with size proper to you current.
Using LC-filters  = 10 uH axial inductors + 10-47 nF capacacitors, are very good and cheap solution for protecting all servo signal lines (specially when you use extending cables).
Marek
RichO:-)
 These filters are good
http://www.flytron.com/70-mickey-1-amper-power-noise-filter.html
Power everything bar escs through one of these. So, basically take power off for all your onboard FPV kit/ BEC after the current sensor through the filter. As with all current sensors do NOT use the GND and + wires, just the current sense output. ;D (big discussion on this by Ren on RC Groups)
mark1975
my my lc filter done today following ian (coyote) mod..cheers ian
I fly alone  (its my only option)
https://www.youtube.com/c/fpvaboveandbeyond?gvnc=
https://plus.goo
Chris R
Here mine for long range Skywalker with 4s 10000mah, tapping 3s power for VTX and Camera.
Nice work lads, have you noticed any difference ?
Chris R
Will let you know when tested.  ;)
mark1975
Yeah me too..not had chance to test yet ''but soon.
https://plus.goo
Chris R
Ok tested LC filter and 99% of interference is gone. :)
