Help needed
Started by Simple simon, July 02, 2013, 11:42:23 PM
Simple simon
Hi all
Recently built a hex with a kk2 controller, could not get it to fly so have upgraded to naza m. Same issues. Flipping upon take off. Is there anyone in the west mids that could spend a short while helping me to solve this???
I've tried everything and now lost the will
Thanks in advance
cortex
This happened to me. You should do away with the bullet connectors and solder the wires directly onto the ESCs.
Simple simon
Hi cortex, why would this be?
Have you checked all the motors are turning the right way and are in the correct order?
Simple simon
Davey
Checked all this but will triple check
cortex
Quote from: Simple simon on July 02, 2013, 11:50:18 PM
http://fpvuk.blogspot.co.uk/2013/03/dji-f450-f550-bullet-connectors.html?m=1
You should do this but keep the female bullets that are attached to esc PCB. Then just solder the motor wire onto the top of the females. Then you have a direct connection. I found it quite difficult to do it the way Simon did it as illustrated In the link above so I found my own way of doing it.
Gwilz
If you've got the old motors with the bit that spins freely on the bullet connector the simplest fix is to tin them slightly with decent solder .. If you've got solid bullets (they will be a very tight fit) you've probably put it together wrong.
Simple simon
Hi guys
Rotation right, props right and calibration done. I need someone to look at it.
skyman(iain)
where are you in the west midlands?
me coventry
you??????
Iain
Simple simon
I'm in Herefordshire but its no problem to travel to get it sorted?
Shikra
if motors spinning right way, its calibrated etc, most probably esc is connected to wrong port on naza
Quote from: Simple simon on July 03, 2013, 08:12:39 PM
Hi guys
Are you 100% on that? Can you put a bit of tape on one side of each blade and post a YouTube vid please?
