Eztracker bad packets
Started by jwmachon, July 04, 2013, 10:33:10 PM
jwmachon
Well got my tracker setup and it works yippee thanks Simon
Went out today to test and it tracked perfectly now the problem I have is bad packets
Rate of less than 57%
Connected it to audio right on the vtx to osd
Sound coming from duo5800 to eztracker
Audio level when close goes from high to ok
I understand that these value are low so what shall I check
Is it worth messing with the volume pot a little
Is audio right the correct one
Jonny
P.s from vtx to osd I have yellow video and green audio right and all works should I have black ground connected
Yes you should have black connected too
Low audio is normally a bad connection on the jack plug of the tracker or a mic on the vtx screwing the signal up
What are the audio levels like? On the tiny telemetry and ezosd you can bump the audio levels up if they are low.
jwmachon
#3
Audio ranges from high to ok so that looks ok not having ground connected wont effect it will it that's just if I'm poweing cam from vtx isn't it but the can is powered seperatly
#4
Check out what version of firmware you have on both the EZOSD and the EZAntennaTracker as I've had the same problem recently when they were mismatched.
EZOSD v1.14 (old) with EZAntennaTracker v1.10 (old) = Works fine
EZOSD v1.20 (new) with EZAntennaTracker v1.10 (old) = 50%+ bad packets
EZOSD v1.20 (new) with EZAntennaTracker v1.14 (new) = Works fine
here's my story on what I found.....
A couple of weeks back I upgraded the firmware on two of my five EZOSD's to v1.20 (from 1.14)
Problems showed up straight away with bad packets on the AZAntenna tracker, showing between 52% to 57%
Tried the EZOSD's through two different 5.8vtx set-ups, and two different 2.4vtx set-ups and they all gave these figures.
My other EZOSD's on v1.14 worked perfectly when plugged in, 100% solid good
One of the v1.14's was then unplugged, flashed to 1.20 and tried, it gave the 52% reading !
flashed it back to v1.14 and it gave 100% good
Then I checked my EZAntenna tracker firmware version, it was at v1.10
quick check on ImmersionRC site and they say v1.14 is latest for their tracker AND recommend updating your EZOSD to 1.20 to work best with it.........
I updated my tracker to the latest v1.14, and tried it with an EZOSD on v1.20 and everything fine and 100% good packets.
So, check what version your tracker shows on start up, and what version your EZOSD shows
If you have v1.10 on tracker AND v1.20 on EZOSD I'd say that's the problem and just upgrade your tracker to the latest v1.14
http://www.immersionrc.com/downloads.php?fpv_download_file=27
Hope that helps  :)
PK
Teamftp
I bet that's the problems as I am fairly sure Jonny had not updated the firmware on it.
Cheers for pointing that out, probably saved hours of prattling about.
jwmachon
that looks like the problem iwill make a note of settings and upgrade firmware im up to date on ezosd and old on tracker and get 52% to 57% lol so looks like the problem.
will update firmware
Teamftp
Will only take a few minutes to set back up this evening mate.
jwmachon
i will take pics of screen b4 upgrade then reenterthem should be ok i will try and do it and watch the video lol
did u find a ubec mate for me to BUY.
Teamftp
Yep got UBEC.  will need your connectors soldering on to it though. Oh and yeh there is a good video to watch LOL:
ImmersionRC FPV EZAntenna Antenna Tracker Setup Guide and Walkthrough of the system.
jwmachon
Pk-surfing thanks a bunch working fine now greatly appreciated
Thanks to Simon aswell for all help
