KK2 no Yaw Input....?
Started by Hubsanman, July 19, 2013, 12:21:57 PM
Hubsanman
 Hi All
Does anyone know why my KK2 Flight Controller  (1.5 firmware) disarms after I land (glad its not whilst flying) with the message "No Yaw Input" If I unplug battery and re connect it
works again.
Is the board fooked or is there a way to reset? any ideas chaps in the know?
FPV Gives You Wings
Hubsan X4  FPV
1.8M SuperCub  TO FPV!
F450  APM3.1 QUAD  FPV
F330  KK2 QUAD FPV
I've seen this a few times as well - although on each occasion, I was in the middle of messing about, or had my radio off so it made sense.  If you go into the receiver test at this point, does your yaw/rudder work ok.
Might have also had this when I'd managed to calibrate the throttle a little too far down, and some of the motors were beeping away trying to tell me that throttle was not zero (when it was) might have had this pop up then as well.  I only mention it  because it seems if part of your config isn't quite right... or set with the KK2, it seems to use this as a weird spurious message - which doesn't necessarily help you track the actual problem down very well.
Derr... Put some more yaw in!  :P
Hubsanman
Quote from: DaveyLC on July 19, 2013, 04:24:35 PM
ha ha very funny mister  :-X the damned Fc went to safe mode and gave me that warning, three more and I get a red card! :P
FPV Gives You Wings
Hubsan X4  FPV
F330  KK2 QUAD FPV
Hubsanman
Today my kk2 reported no throttle. So I thought oh sh*t. Then I realised I had tx on wrong model setup......doh
I still have prob as title says so any further advice welcome.
FPV Gives You Wings
Hubsan X4  FPV
F330  KK2 QUAD FPV
