(Customised) Flyingwings falcon build
Started by skyscraper, July 24, 2013, 02:33:24 PM
Yea so does mine normally mate, but not when the wires go through the motor :laugh:
Actually on further extension, only damage is to a servo extension cable .. fixed :D
I've got the revolution on it. It's got a built in UHF tx/rx for telemetry and rc control, so that will be my rx for the rc.
I've bought a stand alone oplink too that takes the ppm stream in from the trainer port. Means I use that instead of the ezUHF for the falcon
I found adding nose weight made it fly quite a bit faster - a nice wing for sure.
Nice! What powerplant are you running on that??
That goes really well. Must get mine finished!
Mine wasn't as quick as that although I did have the VTX and extra  lipo onboard when I maidened it - only a flight cam to add but I think I might pick up one of those motors as I'm using an old AXN one that to be honest has seen better days.
foamster
Hi Andy,
You maybe exceeding the airframe speed a bit, try some laminating film, down the leading edge.
the motor your using is really only good for a 6x4 apc type, if you want to run an 8x6 then go down to 1400kv.
I use the same motor (2200kv) with a 6x4 and get really good flight time and decent performance.
Like the mod tho, has it reduced any waggle ?
Cheers rob
Yep, interested to see this because I'm wondering whether I should add some tight tape support around the wings crossing across the airframe to stiffen it up a bit - it does feel a bit floppy.
liambaker996
It might feel floppy guys but I have certainly had no problems as standard :)
Liam
a pocket emptyer
and a life long addiction!
frsky taranis, Ezu
Yea but you've not FPVed it either, if you get a bit of lick on it might be enough to make things come loose if it starts to flex...
Can't you just back off the throttle a bit you hoodlum?? :laugh:
Looks good Andy. This is how far mine has got.
