Coyotewing 60" Delta Wing
Started by Coyote, February 01, 2011, 12:07:01 AM
IWCoburg
Thats looking fantastic Ian, nice layout and well built. Should fly like a dream.
Mike.
Lots of multicopters
Badlands
It will def be worth the wait - its looks nice & slippery.
Wow, wow...
That's going to take some hiding in the house !
(p.s  Ian, I've just ordered my EZOSD, RSSI, GPS 10hz, 100amp sensor)
Paul
mark1975
Omg god its eaten the sofa lol..wow thats is one goodlooking wing sweet as ian good buy btw..
https://plus.goo
TerrorTrooper
JESUS!
Cant really appreciate the size until you see it on the sofa!!!    :o
Looks awesome mate!!!
Well another update, i decided to go with the chevrons on the bottom and a tribal design on the top. So Keith and I set about the bottom.
To give you a even better idea of the size, here`s 6ft of me the very proud owner :) Oh and the new look bottom ;)
Cheers lads
Nice one Paul, EZOSD rocks :) It is a big large isnt it Mark lol
Simon, err maybe lol Yes i hope it is worth the wait Martin :)
Even the ASW doesn`t look that big anymore lol
On the ASW i wanted the lower Dragonlink antenna to remain straight, i tried a spring but being metal this would / could effect performance.
With the Coyotewing as with most the antenna being stiff would be no good for landings. Having it in a plastic tube such as a push rod tube would work to a degree but pivoting using the wire would weaken the wire after a while so another solution had to be thought up.
After a few ideas Keith came up with a cracker, the idea being we needed antenna to fold back over for landing but correct itself in flight, have enough strength to combat air over it and place no strain on cable. The answer, cable tie and heatshrink tubing :)
What we did was hot glue the cable ties base to the wing behind the antenna cable, feed it with the antenna up the heatshrink tubing. The cable tied provides the support not the cable, it springs back after bending and has enough strength to cope with winds :)
Forgot to take a pic of us doing it but heres the cable tie behind glued down :
And showing the flexibility of it :
Hey Presto, full range Dragonlink capabilities with a free mod :)
IWCoburg
Great stuff Ian. Should look sweet with some air under it.
Mike.
Pasty
nice Ian!
Whats its all up weight?
any idea of the amp draw you're going to get off that motor and prop combo?
I ask because I'm looking at a 60" wing myself and wonder whether I can get away with a lighter motor and also wonder whether my packs can take the amp draw of a motor  the same as yours.
I'm coming at it from a different angle, lighter the better and more streamlined to extend duration rather than loading it up with mah.
cheers
steve
The AUW is 2.25kg Steve, only .05kg up on Team Black Sheeps art kit i noticed so im not that paranoid at all now which is good.
Give me a few minutes we are just going to run the motor up now
Pasty
#57
well thats 3hrs... didnt let the smoke out did ya? :)
Lol installed windows 7 Ultimate so been busy we`l have a go in a sec :)
Pasty
No worrys, I got the wing sorted so I'm interested to see how your stealth goes with that weight on the single 3s pack.
Gonna be a couple of weeks before I'm looking at getting the motor, you should have had plenty of air time by then...DOSD dependant of course  :'(
