Frsky Rx Aerials
Started by Captain Birdseye, December 28, 2013, 01:20:35 PM
Captain Birdseye
Hi, I'm making the transition from Spektrum to Frsky and in the process of converting a couple of models. What I don't know is how much of the D8R-11 Plus aerial wires are 'active'. As they are diversity devices is it the whole wire or just the  last 30mm or so that need to be positioned correctly?
Thanks in anticipation.
Why is it always cold wet and windy?!
rob.thomson
Just the end bit :)
As above, only the stripped back piece on the end which should be around 32mm
Captain Birdseye
DwayneDibbley
Would this be a correct arrangement for the FrSky Antenna ( one straight down and one a 90 ) ?
or should i get the longer antennas and hang them down in a inverted V?
You can position them like that, a V shape maybe better suited if most of your quad flying
DwayneDibbley
Do you mean the V upright or inverted /\?
