Dynam Hawk sky FPV FINISHED :D
Started by Liam B., January 04, 2014, 04:12:49 PM
Liam B.
Well after procrastinating i've decided "screw it if it flys brilliant if not the bounce will be on video".
So here it is all done and ready to fly tomorrow or even this evening!
Specs are:
2200mah 3s Tunigy nanoshit lipo
1100kv motor
6x4 pusher prop,
30a Hobbyking ESC,
stock 9g servo's,
and my Futaba T8J!
FPV stuff is;
Boscam 200mw vtw,
Boscam Vrx,
Skews!
chris-s
Good use of hot glue and parcel tape! Good luck with the maiden.
Liam B.
Its "plastic reinforcement"  ;D
Cannot wait to fly tomorrow!
Ibbi
Nice one, hope you enjoy your flight.
What are you using to record the video?
Love it so different from the norm good luck on the maiden tomorrow  :D
dizzy :)
Liam B.
Quote from: Ibbi on January 04, 2014, 09:12:20 PM
Nothing atm, the vid'll be LOS to capture the crash!
Liam
Ibbi
Nah, in sure you'll be fine, but I have to say the adrenaline does kick in when you take the goggles off and the pane is nowhere in sight.
Happy flying buddy
tdmodels
Liam - make sure that prop is on the correct way round.  Writing should face the front!    :o
It'll seem like it is still pushing air in the right direction, but you'll have nowhere near the same amount of thrust!!!
FPV God
Liam B.
Swapped it around so the apc prop was correct!
So it flew,  I had to take off with a tail wind to avoid a road!  It's very underpowered, I fought to get it up, then landed!
Thought at one point I'd have lost it after the wing pushed a wing over!
http://youtu.be/ri8Aog61LKE
rob.thomson
My old hawk Skye suffered the same way.
Stock - it has plenty power.
But just the weight of a go pro made it fly like a dog!
You will need to look at a different prop/motor to get some oomph into it.
Liam B.
Yeah, going to keep this prop and put a 2200kv on!
rob.thomson
Yup.
Annoyingly, the pusher config makes it difficult to increase prop size much!
Liam B.
yeah this 6x4 is the largest i can get on it, its also bigger than the stock 5x5!
