Mudders ZII
Started by Mudders, January 11, 2014, 06:37:54 PM
Flyn
Maybe switch then reverse the ail & it'll probably fix you problem ;)
Mudders
No need mate, it's sorted, cheers  ;)
Now, control throws, I assume I set those in the TX?
Muds  :)
Flyn
Cool, how did you sort it?
Yeah control throws set in tx, I just dial down the end points, never had any need for rates as if you set 12mm aileron travel from centre & 10mm elevator travel from centre it'll fly like a dream.
Don't for get to set your reflex, 4-6 clicks of up trim ;)
Mudders
I switched the ail/ele plugs in the OSD out ports, siimples lol.
Reflex - check!
Nearly there  :)
Muds
Flyn
