Mudders ZII
Started by Mudders, January 11, 2014, 06:37:54 PM
Mudders
Thought I'd post a piccy of my ZII. I've slowly been building it in between work over the last month or so. It only needs the gizmo's inside setting up now (ET and taranis stuff).
Mudders
Underside
Sent from my GT-I9505 using Tapatalk
Looks tidy, how long till the maiden?
Very tidy build, like it :)
Mudders
How long till the maiden? I need to get a grip on this complicated Taranis and ETree system (so for an old 38year old numpty maybe quite a while!), I'm having troubles at the moment getting the logger set up, I get errors when trying to send the info to it.
If I can sort it maybe 25th Jan, I'm of to my favorite WW1 aerodrome that weekend.
Muds  :)
Mudders
This whole set up (including TX) is from http://www.efpv.co.uk/
How much depends on what you want to put in it. I opted for the recommended esc and motor and Eagle Tree system with stabilisation and RTH.
Muds
Flyn
NICE dude, love it!!!!
So when we meeting up for the maiden??
Mudders
Cheers matey,
Maiden at Stow on 25th or 26th Jan, IF I can suss the ET out. My head hurts! I eventually got your file to work, but ailerons are reversed, and one elevon always moves more than the other (port for down ele and starboard for up!), I can't work out how to reverse them unless I try on the tx.
When I try and run the servo wizard even that wont write, some warning comes up 'OSD Pro Board is not connected. Please connect the OSD and try again' but it is!
Anyway, your welcome to come play then if your up for it  :)
Muds
Flyn
#8
Cool, sounds like a plan!!!
If you're up this way anytime soon I'll come meet you for a look.
Try re flashing the firmware mate that may help. Also make sure your stabiliser gain is at minimum or it might cause uneven movement.
Bring up display servo defections from one of the menu options too, helps with setup.
Happy to help out with it if you need me to
Mudders
#9
Don't suppose you know where to find the servo deflection screen mate? I searched but...
I just reflashed everything but it's all the same.
Muds  :)
hase2
If you want I can send you my taranis config for the Zeph.
Mudders
Cheers mate, I'll try anything.
After some more playing, I think the only problem I have is reversed elevator. Am I right in thinking I should NOT do this from the TX?
Muds
Flyn
It depends how you've got your servos plugged in, if you can't get the right deflections switch over the servos in the plugs on the osd
Mudders
I'll try it but left and right roll are correct, it's just ele thats reversed  :(
Mudders
Sorted!!
Cheers Flyn that was it  :-* :-* , I switched the ail/ele servo wires in the osd and hey presto!
Right, now to tackle the settings....
Muds
