Main Menu
MFD Autopilot
Started by Gundummy, January 23, 2014, 11:10:49 PM
KillerDave
So, How do we trim the plane if it want to rise or fall, turn left or right in STB mode?
This is how mine flies turns gentle left and descends...
djhandz
Quote from: KillerDave on October 13, 2016, 11:02:12 AM
To trim stab mode use the roll and pitch trims in  the plane settings menu
No he means when he's flying...
Ful size aviation pilots often use trim instead of the controls to pitch or roll in order to have very smooth flight.
Also, trim is used at different throttle settings to maintain level flight
KillerDave
Quote from: djhandz on October 13, 2016, 11:40:46 AM
Ok, thanks...
Then save to model 1 a do a stick cal? or/and common cal???
djhandz
Quote from: KillerDave on October 13, 2016, 01:06:58 PM
Ok, thanks...
Just save. Stick calibration only needs to be done if you alter your tx trims
Maybe he doesn't then lol
KillerDave
Quote from: djhandz on October 13, 2016, 01:17:42 PM
Ok, Thanks....
So in STB, If the plane doesn't want to fly straight, I land, adjust the trims in the OSD, fly and if happy, land and save????
djhandz
Quote from: KillerDave on October 14, 2016, 11:08:36 AM
Ok, Thanks....
Yes..if I remember correctly going up in numbers on roll trims to right and up on pitch trims up
KillerDave
Quote from: djhandz on October 14, 2016, 11:15:41 AM
Great! Many thanks...
Now I just need a nice calm day!...
It's actually great out there now but I'm stuck at work!
Thanks again....
foamster
Hi Guys,
Just a note to say that all the MyFlyDream products (not MTD) are back in stock now !!
Thanks for your patience
http://flyingwings.co.uk/fpv-uav/fpv-systems/autopilots/myflydream.html
Regards Rob
Rommie
Quote from: foamster on October 28, 2016, 03:43:09 PM
Hi Guys,
Regards Rob
Hi rob,
By any chance do you have a spare set of shielded cables for the mfd ap, trying everywhere with no luck have even tried mfd themselves, hoping you may have a faulty unit that has all the cables
Cheers bud
facedown
Quote from: Rommie on October 28, 2016, 06:08:36 PM
Hi rob,
Cheers bud
You can try to make yourself. I use a broken usb cables from mobile charger. I use micro usb cable .
Rommie
Yeah I have made some before just thought I would take the. Easy route well what I thought might have been easy lol
KillerDave
Hi folks,
I am still having a problem calibrating my current sensor....
I have figured out I can change the reading by CURRENT ADJ.
I have a clamp style Amp meter and it's reading 28.2A @WOT.
My OSD is reading around 15A WOT with the CURRENT ADJ at 100% and around 18A with the CURRENT ADJ at 200% (max) WOT...
What am I missing?
