Skew antenna covers
Started by BigT, April 01, 2014, 09:37:19 AM
I want to mount my tx antenna with the lobes underneath the fuselage of my Skywalker. I have tried this and found an improvement in range etc. However the lobes can get all bent up on landing so I am looking for a suitable cover. Is there such a product available or other way of protecting the lobes? I have heard of dipping in latex rubber?
rob.thomson
Probably simplest to make a vacform blister cover?
Not sure why nobody makes and sells them!
Or just make one out of some scrap foam.  Or carve some foam out of the fus and have the antenna just inside instead of sticking out.
Ratty
Cut up the right sized yogurt pot and just glue it over and paint to match.  ;D
How about a 3D printed one? I have printed stuff down to a 1mm wall thickness. Dunno whether that will affect range or not but only one way to find out :)
Let me know some dimensions and I would be happy to give it a go for you ! I'm seeing a nice streamlined airfoild shape in my mind!
Alternatively if you are any good with cad. sens me an .stl of your whims!
Jake Bullit
or treat yourself to a Kinder egg ,then use the toy container on your aerial.
Jake Bullit
Quote from: Jake Bullit on April 01, 2014, 10:48:42 AM
I'm sure it flies lovely, and it doesn't matter how it looks - but the phrase "Discovery: special 'found it on a skip' edition" runs into my head :)
Jake Bullit
Cheeky sod ;) ;D Thats one of my tidy builds too :)
Its been in the wars a bit.
gtv
Quote from: CurryKitten on April 01, 2014, 01:31:22 PM
Lol I didn't want to be the first to say that.........
rob.thomson
Ping pong ball?
rob.thomson
Just mange sure you don't get it hot.
Pinf pong balls are often made of celluloid.  Don't want it to go Puff :)
I thought table tennis ball. I will have a go with solid works  when I get time. Cannot get tt balls locally
Quote from: Loopdreams on April 01, 2014, 10:09:37 AM
. Not strong enough
Quote from: rob.thomson on April 01, 2014, 09:56:05 AM
. Could make a balsa mould?
