fy21ap on the funjet
Started by aaronw, April 15, 2011, 07:44:31 PM
aaronw
anyone set their funjet up with the fy21ap ap117, cant seem to get the ailerons and elevator to work on both wings when i am in ABM , they only work on one ,
twinstar II
funjet
Hirobo .30 lama
Sceadu .50
Loads of Broken stuff!!
Hi,
Don't know if it's any help but page 18 of the PDF instructions says something about Delta wing aileron elevator control that a jumper has to be installed at position 10/CD
aaronw
lol , yep that did it !!! 12 hours of scratching my head , 10 seconds sticking a jumper in!!! must learn to read manual correctly in future. cheers pal
twinstar II
funjet
Hirobo .30 lama
Sceadu .50
Ian F
I am about to fit one to a ritewing, but the instructions show the jumper in 2 different positions. The first drawing has the jumper virticle in row 10 across D + C, the second has it horizontal on the bottom accross 9 + 8. Anyone know which is correct?????
Thanks Ian
est1976
based on the two posts above yours I say 10 C+D it seems to have worked like that for Aarons elevons.
jimbobaddison
I am in the process now of purchasing the autopilot and soon will have it installed in my funjet, if it all works out, I shall be using it in a twinstar or skywalker, cant decide!!!
#6
Hi Giys.
I have 2 fy21ap ap117 setups, on my new one I have mounted the FY21AP without its box, it was easier to fit it in a small cavity, where it doesn't touch anything in the plane which will intrigues vibrations. + it was lighter
will I'm on the subject, it is recommended that a separate battery is used on this setup for the OSD and camera, but on the plane that I'm fitting this one on its only small, so I won't to see if I could use the same flight battery, I was wondering is it beter to get power before it gos through the volt sensor or as it comes out.
thanks.
:) G
