Robs Wicked Wing Remix
Started by rob.thomson, May 23, 2014, 03:36:46 PM
rob.thomson
Yup.  Its originally a slope combat model.
Fast... And stupid maneuverable.
Think loops in 1m diameter :)
rob.thomson
The wickedFPV wing flies!
Only done first trim LOS.
I needed about 15g lead up front to balance it.  And a washer to get the thrust line right.
Seems to track quite well.
FpV flight to follow...
Looks handsome. Does it feel like it's going to be a good un?   :)
rob.thomson
Possibly...
I need some more air time with it to be sure :-)
Lets say.. it will be 100% better than the X-5.
rob.thomson
Right.
Went for another flight.  Still LOS.
I am VERY HAPPY.
I ended up adding a little more weight up front.  It was just too unstable in the regular slope combat position!
The model tracks really well - and is stupid fast!
I am flying with a 1000kvm motor, with an 8x6 prop.  It can pretty much go vertical!
It will cruise happily on 1/4 throttle.  Loops, Bunts, Rolls - all dead easy and relatively smooth.
Result.
Now.. here is the fun bit.
These models cost around £30 delivered.  This includes covering material.  To full complete with esc, motor etc...  I would guess around £80.  Then the fpv gear.  So maybe £150 all up for a basic setup.
Not bad!
Compared to something like the Phantom.  Its a harder install.  But it flies possibly better (assuming what you want is a rocket that is aerobatic!)
Sounds great. I'm glad the alternative tail arrangement is working too. I find it more robust than having fins at the wingtips.
rob.thomson
Certainly makes launching it easier!
rob.thomson
Quick video from earlier today..
https://www.youtube.com/watch?v=NijNgzRKqrw&feature=youtu.be&safe=active
There was a little bit of noise at certain throttle settings - just fixed that by moving wires and sourcing the power for the video system from the balance lead.
Hmm, it still seems to waggle a fair bit
rob.thomson
A bit - but getting better each time as I am gradually getting the cg and thrust lines right :)
Where it does waggle more is if I slow it down.
Quote from: rob.thomson on June 01, 2014, 09:46:33 AM
Maybe add some winglets as well? They do also separate the upper and lower wing pressures and prevent vortices.
rob.thomson
I was actually thinking some fences half way down the wing.    They should enable me to push the cg back slightly too.
I found that this style of fin still had some movement on my Falcon at slow speeds. maybe a bigger and more efficient fin shape. Taller and thinner with a straighter leading edge. More wing like! would help
rob.thomson
May give that a try.  I have loads of correx to hand :)
