Robs Wicked Wing Remix
Started by rob.thomson, May 23, 2014, 03:36:46 PM
rob.thomson
Been meaning to do this for a while...
Its a 1.5m wicked wing slope soarer.
I have popped a motor on board, and nodded the fins + pushing them way way back to eliminate yaw rock.
It will carry a 2200mah pack with a 900kv motor, so should get me 15 to 20 mins of fun :)
Rob
Looks nice :) Are the booms for the fins not going to flex easily ?
rob.thomson
Nope.
6mm carbon tube.
They are mounts onto a large ply plate I buried into the foam.
Looks Very Nice!  Looking forward to seeing how it goes!
Looks good that, hope it works - won't they vibrate a bit in prop wash though?
Suppose it's one of those DIY things that you never know if it'll work until you try :D
rob.thomson
A few note pics...
Fins removed..
Underside
Top
Sideish view
rob.thomson
Quote from: Steve W on May 23, 2014, 05:57:23 PM
Shouldn't be an issue.The prop is about 5cm from them.
If you see the pictures, the rods are quite secure.
Even if it does vibrate - don't think it will be any impact on flight as no control surface on them!
Paul881
Rob, what's the advantage of boom tails over vertical wing stabilizers?
rob.thomson
Gets then well behind the cog.
Result is theoretically less wing rock.
It also means that discus launching it will be easier.
krikey
I would suspect that because the wing yaws around the cofg, as the wings are far back any yaw is amplified at the rear stabs hence presumably they would reduce the amount of yaw as they are more "sensitive" to it that's my theory ;)
Krikey
Krikey
rob.thomson
More or less correct.
They have in effect more leverage!
krikey
that's the description I was aiming for :)
Krikey
Krikey
rob.thomson
Control surfaces installed....
Most electrics now in place.
Once my servos arrive - I can wire in and cover the beast!
Looking really good. If C.G is correct with the battery there then its sure one up on the likes of the Venturi! Must be quite light too..?  Should be quite floaty!
Those elevons are massive, must need only a tinnnnny amount of movement for control
