hitec compatible receiver
Started by subarubren, June 21, 2014, 05:43:35 PM
subarubren
ive been using one of these receivers http://www.hobbyking.com/hobbyking/store/__27175__2_4Ghz_A_FHSS_Compatible_8CH_Receiver_Hitec_Minima_compatible_.html like a knob ive managed to pull one of the aerials of today, anyone know if it will work with just the one  :-X
Like Clunk says, you could easily mend it. just solder in a bit of reasonably thin wire that's the same length as the other side. If you cut the wire within 1cm of the correct length then you've probably well exceeded HobbyKing's quality control.
